cant install program
i cant install my 3ds max, i use to have it installed a while ago and removed due to not using i am now trying to install again and i keep getting this message, as in picture
Mark.Lancaster
mazza127
Welcome to the community...
On that dialog that indicates the failed installation of your product is a link to your installation file.  Post it here as a text file so we can review it to see what's going on.   However I'm going to assume you were using the install now option...
So give this a try...  Go to the Autodesk Virtual Agent and follow the download links to your product.  Download all of the parts first (some applications may only have a single part to download) and then go to your download location.  Extract (double click) part 1 (or the single part download) and in a few seconds the extraction will start.   It will then prompt you to extract to C:\Autodesk and once the extraction is finished the installation will start.  Also make sure you have admin rights, UAC is turned off and Anti-Virus temporary disabled prior to installation.
Mark Lancaster
hi, thanks for getting back to me , this is the installation log after it fails
2016/3/25:11:55:31 mallory MALS === Setup started on MALS by mallory ===
2016/3/25:11:55:31 mallory MALS Path_Length: 148
2016/3/25:11:55:31 mallory MALS Current Directory C:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_wi_en-US
2016/3/25:11:55:31 mallory MALS Launch
2016/3/25:11:55:31 mallory MALS CommandLine /akamai /sid a1b30000008r7SPAAY /skipEULA /skipPI /url "http://efulfillment.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_...
2016/3/25:11:55:31 mallory MALS Current Directory C:\Users\mallory\AppData\Local\Temp\_AIA5A2.tmp
2016/3/25:11:55:33 mallory MALS === Setup ended ===
2016/3/25:11:55:32 mallory MALS Download Skipped SETUP_CONFIG http://efulfillment.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SET...
2016/3/25:11:55:32 mallory MALS PageOpen LaunchDialog
2016/3/25:11:55:40 mallory MALS PageOpen LicenseDialog
2016/3/25:11:55:40 mallory MALS PageOpen ProductInfoDialog
2016/3/25:11:56:02 mallory MALS PageOpen ProductSelectionDialog2
2016/3/25:11:56:05 mallory MALS PageOpen FullProgressDialog
2016/3/25:11:56:05 mallory MALS Download Skipped VCREDIST2012X86 http://efulfillment.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCR...
2016/3/25:11:56:05 mallory MALS Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2016/3/25:11:56:11 mallory MALS Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2016/3/25:11:56:11 mallory MALS Download Skipped VCREDIST2012X64 http://efulfillment.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCR...
2016/3/25:11:56:11 mallory MALS Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2016/3/25:11:56:20 mallory MALS Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2016/3/25:11:56:20 mallory MALS Download Skipped DIRECTX http://efulfillment.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/DIR...
2016/3/25:11:56:20 mallory MALS Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\DirectX\DXSETUP.exe" /silent
2016/3/25:11:56:24 mallory MALS Install DirectX® Runtime Succeeded
2016/3/25:11:56:24 mallory MALS Download Skipped CM http://efulfillment.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CM....
2016/3/25:11:56:24 mallory MALS Installing Autodesk® Material Library 2015: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2015" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0264-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/3/25:11:56:46 mallory MALS Install Autodesk® Material Library 2015 Succeeded
2016/3/25:11:56:46 mallory MALS Download Skipped CMILB http://efulfillment.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CMI...
2016/3/25:11:56:46 mallory MALS Installing Autodesk® Material Library 2015 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2015" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0264-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{427F733F-4D6C-45BC-9324-EB743104C321},;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/3/25:11:57:20 mallory MALS Install Autodesk® Material Library 2015 - Base Image Library Succeeded
2016/3/25:11:57:21 mallory MALS Download Play CMILM http://efulfillment.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CMI...
2016/3/25:12:01:22 mallory MALS Download Aborted CMILM http://efulfillment.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CMI...
2016/3/25:12:01:22 mallory MALS Install Autodesk® Material Library 2015 - Medium Resolution Library Failed Download Failed, Installation aborted, Result=1603
2016/3/25:12:01:33 mallory MALS Rollback Autodesk® Material Library 2015 - Base Image Library Succeeded
2016/3/25:12:01:58 mallory MALS Rollback Autodesk® Material Library 2015 Succeeded
2016/3/25:12:01:58 mallory MALS Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2016/3/25:12:01:58 mallory MALS Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Failure is ignored, Result=1619
2016/3/25:12:01:58 mallory MALS Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Failure is ignored, Result=1619
2016/3/25:12:01:59 mallory MALS PageOpen InstallCompleteDialog
2016/3/25:12:10:43 mallory MALS === Setup ended ===
2016/3/25:12:48:46 mallory MALS === Setup started on MALS by mallory ===
2016/3/25:12:48:46 mallory MALS Path_Length: 148
2016/3/25:12:48:46 mallory MALS Current Directory C:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_wi_en-US
2016/3/25:12:48:46 mallory MALS Launch
2016/3/25:12:48:46 mallory MALS CommandLine /akamai /sid a1b30000008r7xcAAA /skipEULA /skipPI /url "http://efulfillment.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_...
2016/3/25:12:48:46 mallory MALS Current Directory C:\Users\mallory\AppData\Local\Temp\_AI64F1.tmp
2016/3/25:12:48:48 mallory MALS === Setup ended ===
2016/3/25:12:48:47 mallory MALS Download Skipped SETUP_CONFIG http://efulfillment.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SET...
2016/3/25:12:48:47 mallory MALS PageOpen LaunchDialog
2016/3/25:12:48:52 mallory MALS PageOpen LicenseDialog
2016/3/25:12:48:52 mallory MALS PageOpen ProductInfoDialog
2016/3/25:12:50:19 mallory MALS PageOpen ProductSelectionDialog2
2016/3/25:12:50:21 mallory MALS PageOpen FullProgressDialog
2016/3/25:12:50:22 mallory MALS Download Skipped VCREDIST2012X86 http://efulfillment.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCR...
2016/3/25:12:50:22 mallory MALS Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2016/3/25:12:50:23 mallory MALS Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2016/3/25:12:50:23 mallory MALS Download Skipped VCREDIST2012X64 http://efulfillment.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCR...
2016/3/25:12:50:23 mallory MALS Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2016/3/25:12:50:24 mallory MALS Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2016/3/25:12:50:24 mallory MALS Download Skipped DIRECTX http://efulfillment.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/DIR...
2016/3/25:12:50:24 mallory MALS Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\DirectX\DXSETUP.exe" /silent
2016/3/25:12:50:28 mallory MALS Install DirectX® Runtime Succeeded
2016/3/25:12:50:28 mallory MALS Download Play CMILM http://efulfillment.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CMI...
2016/3/25:13:03:36 mallory MALS Download Aborted CMILM http://efulfillment.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CMI...
2016/3/25:13:03:36 mallory MALS Install Autodesk® Material Library 2015 - Medium Resolution Library Failed Download Failed, Installation aborted, Result=1603
2016/3/25:13:03:36 mallory MALS Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2016/3/25:13:03:36 mallory MALS Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Failure is ignored, Result=1619
2016/3/25:13:03:36 mallory MALS Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Failure is ignored, Result=1619
i am currenly trying to download from the virtual agent at the moment so hopefully that works
Mark.Lancaster
@Anonymous
Download and Install the Medium Resolution Material library for your version from here.   Once that is completed.  Follow my steps regarding the virtual agent.
Mark Lancaster
thank you very much for your help, that worked and program installed
