@meshaal.s
Yes that's the log file needed. But I guess you never took my posting seriously enough about not sharing your sensitive information here. Because your log file contains your serial # and you just shared it on an open public forum..
Make sure you don't do that...
Now to your problem.. Your installation is simply failing due to the method you're using. Use the information that @pendean has linked you to.
Mark Lancaster
& Autodesk Services MarketPlace Provider
