Can't run Maya 2017 on debian 9
Hi everyone!
I am trying to get Maya 2017 working on my debian 9 but it is impossible for me because it just crashes on launch with fatal error:
I am using propietary NVIDIA drivers and Houdini and Nuke are both perfectly working, i have configured my maya.env file with the following lines:
MAYA_DISABLE_CIP=1
LC_ALL=C
There is my crash report
//crash log file name     = /usr/tmp/sergio.20170228.1249
//cut            = 201702071345 /local/S/Maya_2017_DI/build
//host name      = debian
//release name   = 4.9.0-1-amd64
//version        = #1 SMP Debian 4.9.6-3 (2017-01-28)
//machine name   = x86_64
//current scene  = unDisclosed
//directory      = /home/sergio
//command history (most recent last):
  /usr/autodesk/maya2017/lib/libOGSDeviceOGL-16.so(+0x43309) [0x7fc957d49309]
  /usr/autodesk/maya2017/lib/libOGSDeviceOGL-16.so(+0x38e1a) [0x7fc957d3ee1a]
  /usr/autodesk/maya2017/lib/libOGSDeviceOGL-16.so(+0x2453d) [0x7fc957d2a53d]
  OGS::Devices::Sys::CreateVirtualDevice(OGS::Devices::ACreationParameters*)
  CreateOGSDevice(OGS::Devices::ACreationParameters*)
  OGSRenderer::initializeOGSDevice(OGS::Objects::UString*, int)
  OGSMayaRenderer::initialize(OGSRenderer::DeviceAPI, int, void*, void*, void*, bool)
  OGSMayaBridge::CreateOGSRenderer()
  OGSMayaBaseRenderer::initialize()
  OGSViewportRenderer::initialize()
  OGSMayaBridge::Create3DViewportRenderer()
  /usr/autodesk/maya2017/bin/maya.bin() [0x417f1b]
  Tapplication::start()
  /usr/autodesk/maya2017/bin/maya.bin() [0x40ef90]
  main
  __libc_start_main
  /usr/autodesk/maya2017/bin/maya.bin() [0x40e82d]
//Memory usage:
// 12518.531 Mb	Free Memory
// 33829.155 Mb	Free Swap
//  100.236 Mb	Heap
and here my terminal report
root : ERROR : code for hash md5 was not found.
Traceback (most recent call last):
  File "/usr/autodesk/maya2017/lib/python27.zip/hashlib.py", line 147, in <module>
    globals()[__func_name] = __get_hash(__func_name)
  File "/usr/autodesk/maya2017/lib/python27.zip/hashlib.py", line 97, in __get_builtin_constructor
    raise ValueError('unsupported hash type ' + name)
ValueError: unsupported hash type md5
root : ERROR : code for hash sha1 was not found.
ValueError: unsupported hash type sha1
root : ERROR : code for hash sha224 was not found.
ValueError: unsupported hash type sha224
root : ERROR : code for hash sha256 was not found.
ValueError: unsupported hash type sha256
root : ERROR : code for hash sha384 was not found.
ValueError: unsupported hash type sha384
root : ERROR : code for hash sha512 was not found.
ValueError: unsupported hash type sha512
Graphic device does not support OpenGL Core Profile, fallback to OpenGL renderer.
Stack trace:
  main
  __libc_start_main
Fatal Error. Attempting to save in /usr/tmp/sergio.20170228.1249.ma
Writing crash report in /usr/tmp/sergio.20170228.1249.crash
/usr/autodesk/maya2017/bin/senddmp.app/senddmp.bin: error while loading shared libraries: libgstinterfaces-0.10.so.0: cannot open shared object file: No such file or directory
Thank you very much for your help
Darin.Green
@Anonymous
First of all, Debian in general is unstable so I would recommend installing a supported version of Linux and then install Maya:
Maya 2017 System Requirements
If this information was helpful, please consider using the Accept Solution
Hi. The problem with the hashlib I solved by symlinking the hashlib python binary module from /usr/lib to /usr/autodesk.
sudo mv /usr/autodesk/maya2017/lib/python2.7/lib-dynload/_hashlib.so /usr/autodesk/maya2017/lib/python2.7/lib-dynload/rhel_hashlib.so
sudo ln -s /usr/lib/python2.7/lib-dynload/_hashlib.x86_64-linux-gnu.so /usr/autodesk/maya2017/lib/python2.7/lib-dynload/_hashlib.so
As for the video, I'm using an optimus laptop and optirun. In my case, the solution was to download and install VirtualGL manually because Debian 9 doesn't have it in the official repository. Before that, Maya somewhat worked under the intel video but threw the same error with the nvidia's backing.
wget https://downloads.sourceforge.net/project/virtualgl/2.5.2/virtualgl_2.5.2_amd64.deb
sudo dpkg -i virtualgl_2.5.2_amd64.deb
If you have a nVidia video card you can try this:
sudo ln -s /usr/lib/nvidia-375/libGL.so /usr/autodesk/maya2017/lib/
where -375 is the major version of your drivers. Hope it'll work for you.
It seems like you don't have proper graphics driver and libraries .Try to install the latest copy of the graphics drivers as well.
