Having a tough time getting this to install. I've tried multiple computers, one deployment with updates and modifications, another just straight generic install. It seems to be hanging up on C++ 2005 Redistributable.
I found several threads on this topic and here is what I've already tried:
uninstalling all C++
cleaning out temp directory
creating a C:\temp directory
turning off windows updates & virus scan.
I've tried on two different computers now with the same results. I've installed Civil 3D, Navisworks, recap, plain AutoCAD from the same media with no issues. I've also tried creating a new deployment from the same media.
Any suggestions on what to try next?
Here is the contents of the deployment log file:
2017/3/17:11:12:50 DWilson BBG-SDI === Setup started on BBG-SDI by DWilson ===
2017/3/17:11:12:50 DWilson BBG-SDI Path_Length: 162
2017/3/17:11:12:50 DWilson BBG-SDI Current Directory C:\Users\DWilson\AppData\Local\Temp\_AI66D4.tmp
2017/3/17:11:12:50 DWilson BBG-SDI Launch
2017/3/17:11:12:50 DWilson BBG-SDI Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\DWilson\AppData\Local\Temp\_AI66D4.tmp\Setup\AcSetup.dll
2017/3/17:11:12:50 DWilson BBG-SDI Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/3/17:11:13:03 DWilson BBG-SDI Install CustomCallback Info Invoking custom callback for details: [RCL] CB_FUNC=CustomCallbackRevitContentWarning CB_SOURCE=C:\Users\DWilson\AppData\Local\Temp\_AI66D4.tmp\Setup\RevitSetup.dll
2017/3/17:11:13:03 DWilson BBG-SDI Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=Deselecting the content installation will affect critical settings in Autodesk® Revit® 2017. URLTitle= URLLink=
2017/3/17:11:13:05 DWilson BBG-SDI Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): "\\draperaden.net\daa\CAD\install\2017\IDS-P\Img\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe" /q
2017/3/17:11:13:10 DWilson BBG-SDI Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Succeeded
2017/3/17:11:13:10 DWilson BBG-SDI Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64) 9.0.30729.6161: "\\draperaden.net\daa\CAD\install\2017\IDS-P\Img\3rdParty\x64\VCRedist\2008SP1.6161\vcredist_x64.exe" /q
2017/3/17:11:13:15 DWilson BBG-SDI Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) 9.0.30729.6161 Succeeded
2017/3/17:11:13:15 DWilson BBG-SDI Installing Microsoft Visual C++ 2005 Redistributable (x86): "\\draperaden.net\daa\CAD\install\2017\IDS-P\Img\3rdParty\x86\VCRedist\2005\vcredist_x86.exe" /q:a /T:C:\WINDOWS\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\DWilson\AppData\Local\Temp\vcredist_x86_2005.log"" "
2017/3/17:11:13:17 DWilson BBG-SDI Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1603
2017/3/17:11:13:23 DWilson BBG-SDI === Setup ended ===
2017/3/17:11:12:38 DWilson BBG-SDI === Setup started on BBG-SDI by DWilson ===
2017/3/17:11:12:38 DWilson BBG-SDI Path_Length: 162
2017/3/17:11:12:38 DWilson BBG-SDI Current Directory \\draperaden.net\daa\CAD\install\2017\IDS-P\Img
2017/3/17:11:12:38 DWilson BBG-SDI Launch
2017/3/17:11:12:38 DWilson BBG-SDI CommandLine /qb /I \\draperaden.net\daa\CAD\install\2017\IDS-P\Img\Revit2.ini /Trial /language en-us
2017/3/17:11:12:38 DWilson BBG-SDI Current Directory C:\Users\DWilson\AppData\Local\Temp\_AI66D4.tmp
2017/3/17:11:13:46 DWilson BBG-SDI === Setup ended ===
