Can't install 2020 version
jcrispino3
jcrispino3
Having difficulty getting through 2020 install.  Keeps stalling on "Autodesk Material Library 2020 - Base Image..."  Tried installing AutoCad 2020 and AutoCad Electrical 2020, both stalled at the same point.
natasha.l
Hello @jcrispino3
Thank you for posting to the community.
You can try to install the Materials Library 2020 manually from the contents folder, with the steps outlined in this article
Then run the installer (setup.exe) again.
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
jcrispino3
Took a bit to find the folder, but that did the trick!!!
