Autodesk Revit 2024 is already installed while installing... ?????
mr.engineer.aec
Message 1 of 37
mr.engineer.aec
 Hi all,
 I'm installing Revit 2024 but this notification visible ??
 How can i solve this issue ?
 Absolutely, i haven't install it.
Replies (36)
Message 21 of 37
g210104563
Observer
Observer
AutoCAD instal
Message 22 of 37
rachel6FW2H
Community Visitor
Community Visitor
I followed all the instructions above. Updated the Registry keys, totally removed, then reinstalled with the same error. This really needs to be fixed by AutoDesk. It's ridiculous that we have to go to so much trouble for a complete uninstall just to find the reinstall doesn't work!
Message 23 of 37
pendean
Community Legend
Community Legend
@rachel6FW2H wrote:
...This really needs to be fixed by AutoDesk...
How to open a support case with Autodesk if you are on subscription to seek out Autodesk Support's help:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-find-my-sup...
Message 24 of 37
2018025561
Community Visitor
Community Visitor
will i just delete the file?
Message 25 of 37
kt_eritaia
Community Visitor
Community Visitor
Autodesk products messed up and unfortunately uninstalled all! That was a mistake for an issue with Revit 2024! After deleting the two registry entries, installation went smoothly. Thanks a bunch!
Message 26 of 37
temah01p
Observer
Observer
After the 2025.2 update installed there was an issue with the materials graphics tab.
Looking at forums on here I uninstalled 2025.2
That only led to a huge amount of problem.
It led me to resorting to follow instructions to delete any registry keys that related to Revit 2025.
Now every time I try to install Revit 2025 it thinks it is still installed despite me removing ALL remnants of 2025 per all the instructions.
Trying to follow the Autodesk advice of using the Microsoft Troubleshooting tool is useless advice as this tool does not even work in that it won't run due to "errors".
Essentially any attempt to reinstate Revit 2025 has failed.
Message 27 of 37
Thanos603
There is a known issue with side by side installations of Revit 2024 and 2025 where uninstalling one will results in the removal of the materials files necessary to populate the Graphics tab of the Materials browser. At this time, the best solution is to reinstall the version of Revit that was uninstalled, which will restore the missing materials files. Another solution would be to contact Autodesk support, who should be able to provide a zip file from which the missing materials files can be restored.
If your attempts to reinstall Revit 2025 end with a message that this release is already installed, I would recommend searching for and deleting the following registry keys:
HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\UPI2\{FD1D3188-485A-40A9-8D09-0E0817E8299B}
HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Installer\Products\0A4B643700520150000007C5D0680240
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{686CE2A3-7C33-3AD5-806A-75A6E648117F}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{7346B4A0-2500-0510-0000-705C0D862004}
Anthony Michniewicz
Principal QA Analyst
Message 28 of 37
ehelmand
Observer
Observer
I have deleted this one. And it works
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{7346B4A0-2400-0510-0000-705C0D862004
Message 29 of 37
ehelmand
Observer
Observer
This works for me.
Message 30 of 37
ehelmand
Observer
Observer
it works for me. this is how you open registry editor.
  1. Press Windows Key + R: This key combination opens the Run dialog box.
  2. Type “regedit”: In the Run dialog box, type “regedit” (without quotes) into the text field.
  3. Press Enter or click OK: Hit Enter on your keyboard or click OK to launch the Registry Editor.
Message 31 of 37
ukasha_wasil2002
Community Visitor
Community Visitor
Hi all,
Message 32 of 37
ukasha_wasil2002
Community Visitor
Community Visitor
Hi all,
Message 33 of 37
Simon_Weel
Look in path C:\ProgramData\Autodesk\Uninstallers. If there's a folder Autodesk Revit 2024 - delete this folder an try installation again.
Message 34 of 37
m_faizi7WL8V
Community Visitor
Community Visitor
THANK YOU!
Message 35 of 37
hbasavaraja959
Community Visitor
Community Visitor
i agree and reneval this app
Message 36 of 37
fhsvcasv
Community Visitor
Community Visitor
Afte I have installed Autodesk Revit 2024, I coul not able to install any Autodesk softwares like AutoCAD, Navisworks Manage and etc. How can I resolve this issue?
Message 37 of 37
pendean
Community Legend
Community Legend
Not enough information: show us screenshots of error messages, post installation logs of these other software etc. But first, restart your PC and log into Windows as a full system administrator first.
