Autodesk Maya & Mudbox 2017 Linux install failure
I have downloaded and attepted to insyall maya and mudbox with the instructions provided on Arch linux with failure with both i am faced with these respective error messages after activating my licences with the installer
Maya:
Could not launch rpm executable (/home/%USERNAME%/Downloads/maya).
Traceback (most recent call last): File "./unix_install.py", line 227, in shutil.copy(os.path.join(installDir, 'arnoldRenderer.xml'), os.path.join(renderDescFolder, 'arnoldRenderer.xml')) File "/usr/lib/python3.6/shutil..py", line241, in copy copyfile(src,dst, follow_symlinks=follow_symlinks) File "/usr/lib/puthon3.6/shutil.py", line 121, in copyfile with open(dst,'wb') as fdst: FileNotFoundError: [Errno 2] No Such File Or Directory: '/usr/autodesk/maya2017/bin/renderer/Desc/arnoldRenderer.xml'
Mudbox:
Could not launch rpm executable (/home/%USERNAME%/Downloads/mudbox).
any help would be greatly appreciated since I start university soon
Otto
Hello 643222 and welcome to the Autodesk community!
It looks like you need to find out more about downloading or re-downloading software, or are having issues that may be resolved by re-downloading.
For Windows users, before downloading products on Windows 10, please check that the product is compatible.
For general information about downloading or re-downloading (including eligibility), Community members with similar questions found the following article(s) useful:
Download Finder
Previous Versions of Autodesk Software
Download Methods
Find Your Eligibility for Previous Versions of Autodesk Software
Oftentimes installation and/or download issues can be addressed by using a different download method, or by downloading directly from the Autodesk Virtual Agent. Community members with similar issues found the following article(s) useful:
Software & Downloads
Downloading Previous Versions of Autodesk Software Using the Virtual Agent (Please be sure to disable your firewall and anti-virus before downloading)
Performing a Clean Uninstall
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
i have re downloaded and attempted another reinstall, and faced the same error.
after attepting to install maya 2017 patch 4 via "pacaur -S maya" i then was met with a validation error, after that i ran the setup file that came with the tgz file that i previously extracted, now after this i get just the "Could not launch RPM Executable" Error, and the files are marked as executable before you ask. what is Maya actually attepting to 'Launch' the RPM with? because all i can tell is that an RPM is an archive, not an executable program, so it must be trying to run it with a 3rd party program...
