Autodesk design suite ultimate 2016 installation issues
I have installed the above package on my computer via the 7 part links that the autodesk team have given me. Installation was successful, however I have only got AutoCAD, Revit, Revit viewer, Navisworks Manager, autodesk recap. Apparently I should have more softwares loaded like 3d studio max, inventor and things like this, which I have not got. I have been advised to write this forum to get help. Thanks.
Otto
Hello guv114 and welcome to the Autodesk community!
It looks like you are having Revit installation issues. Community members with similar questions found the following article(s) useful:
For issues with Revit Server, please see the System Requirements for Revit Server.
If you are installing on Windows 10, please check that your product is compatible.
Software & Downloads
Downloading Previous Versions of Autodesk Software Using the Virtual Agent (Please be sure to disable your firewall and anti-virus before downloading)
Performing a Clean Uninstall
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
BJ.C
Hello @Anonymous
Try running the install again.  It will tell you what products are installed and give you the option to choose which products you want to install.
Thank you for taking part in our community forum!
Kind Regards,
BJ.C
Technical Support Specialist
Mark.Lancaster
To add to BJ.C. posting..
Which design suite do you actually have?
Meaning there's no such thing just as Autodesk Design Suite..  There's AutoCAD Design Suite..  Product Design Suite, Factory, Building Design Suite, and etc..   So Im wondering if you downloaded the correct one.
Mark Lancaster
Hi Thanks for your replies.
i apologies, it is actually Building_Design_Suite_Ultimate_2016_r2_  is being installed on windows 10 64 bit laptop (just recently purchased laptop with dedicated graphics card, i7 processor, 256ssd) so im assuming the spec should be adequate.
I will try and clicking the link to install again and see what happens (as per BJ.C. posting). I will let you know what happens.
many thanks
g
All,
i have re-installed and clicked the relevant softwares that i want to install individually. It works fine now.
thanks.
gourav
