Below is a description and screenshots of our issue. Furthermore the issue also applies to CFD 2021 for all our users. We have not yet been able to use CFD 2021. Also using a remote solver regardless of the version, does not work which we assume is also related to the licensing issue described below.
Whenever User A open Autodesk CFD 2019 and is assigned a SCFDA_2019_0F license.
User A is unable to solve and the following error message appears:
User B opens Autodesk CFD 2019 and is assigned a SCDSE_2019_0F license.
User B is able to open both the user interface application and solve.
Both users has the same folders in the CLM\LGS folder.
Both users has the same configuration files in the 810K1_2019.0.0.F folder (CFD Premium productcode) and 812K1_2019.0.0.F (Design Study Environment productcode)
Both users are running the exacts same version of CFD 2019
User A
User B
Below is a description and screenshots of our issue. Furthermore the issue also applies to CFD 2021 for all our users. We have not yet been able to use CFD 2021 yet. Also using a remote solver regardless of the version, does not work which we assume is also related to the licensing issue described below.
User A
User B
Below is the output from our Flexnet license manager version 11.16.2
Status
Flexible License Manager status on Tue 2/23/2021 11:09
[Detecting lmgrd processes...]
License server status: 27000@SJ-LICENS
License file(s) on SJ-LICENS: C:\License\Autodesk\Autodesk_all02022021.lic:
SJ-LICENS: license server UP (MASTER) v11.16.2
Vendor daemon status (on SJ-LICENS):
adskflex: UP v11.16.2
Feature usage info:
Users of 86029SCFDA_T_F: (Total of 1 license issued; Total of 1 license in use)
"86029SCFDA_T_F" v1.000, vendor: adskflex, expiry: 03-mar-2022
vendor_string: commercial:extendable
floating license
che SJ0159 SJSURFACE091 (v1.000) (SJ-LICENS/27000 212), start Tue 2/23 11:07
Users of 86035SCDSE_T_F: (Total of 1 license issued; Total of 0 licenses in use)
Users of 86802PLC0000023_T_F: (Total of 1 license issued; Total of 0 licenses in use)
Users of 87032PLC0000023_2018_0F: (Total of 1 license issued; Total of 0 licenses in use)
Users of 86802PLC0000023_2017_0F: (Total of 1 license issued; Total of 0 licenses in use)
Users of 87532SCDSE_2021_0F: (Total of 1 license issued; Total of 0 licenses in use)
Users of 87374SCDSE_2020_0F: (Total of 1 license issued; Total of 0 licenses in use)
Users of 87202SCDSE_2019_0F: (Total of 1 license issued; Total of 0 licenses in use)
Users of 87030SCDSE_2018_0F: (Total of 1 license issued; Total of 0 licenses in use)
Users of 86806SCDSE_2017_0F: (Total of 1 license issued; Total of 0 licenses in use)
Users of 86546SCDSE_2016_0F: (Total of 1 license issued; Total of 0 licenses in use)
Users of 87610SCFDA_2021_0F: (Total of 1 license issued; Total of 0 licenses in use)
Users of 87372SCFDA_2020_0F: (Total of 1 license issued; Total of 0 licenses in use)
Users of 87203SCFDA_2019_0F: (Total of 1 license issued; Total of 1 license in use)
"87203SCFDA_2019_0F" v1.000, vendor: adskflex, expiry: 03-mar-2022
floating license
che SJ0159 SJSURFACE091 (v1.0) (SJ-LICENS/27000 112), start Tue 2/23 11:07
Users of 87029SCFDA_2018_0F: (Total of 1 license issued; Total of 0 licenses in use)
Users of 86805SCFDA_2017_0F: (Total of 1 license issued; Total of 0 licenses in use)
Users of 86541SCFDA_2016_0F: (Total of 1 license issued; Total of 0 licenses in use)
Status
Feature usage info:
floating license
floating license
