Autodesk CER Service 7.0.3
brian.strandberg
Advisor Advisor
brian.strandberg
I can see in Autodesk Access Autodesk CER Service has updated to 7.0.3.  Is there any more information on this and why it should be updated?  I don't like to install this on 150 computer unless there is a good reason.  There isn't much actual detail here to make a decision.
The release notes has even less information. 7.0.3_release_note.pdf (autodesk.com)
Check out my Civil 3d blog at: http://c3dk.com/
Favorite Posts: Use Dynamo For Surface Analysis: https://youtu.be/eJNdX6guMP8
Fast Track your site grading with the new Corridor Workflow: https://youtu.be/Gg7u9-LgIL0
pendean
Community Legend
Community Legend
@brian.strandberg wrote:
...I don't like to install this on 150 computer unless there is a good reason...
Since it is not a REQUIRED update, there is no good reason. So you are not obliged to do anything my friend.
Do you typically like to install and allow CERs on your PC or laptop to freely use your bandwidth without permission every single time? It's not there to fix anything you will trigger as a crash, or tell you why you crashed for example.
Just wondering.
brian.strandberg
Thats the thing - if I have a stable system I don't want to risk an update.  If I had more information about what this was going to do for me instead of vague promises, that would help with deciding to install it.
Simon_Weel
I was curious too about that 'Number of new features and improvements' so I created a service request and this is the response:
Please go through the following features
Enhanced Error Reporting:
Improved mechanisms for capturing and reporting software errors, which helps Autodesk diagnose and address issues more effectively.
Enhanced data collection for better analysis of error patterns and trends.
Performance Improvements:
Optimized the performance of the error reporting service to minimize its impact on overall system performance.
Reduced the time taken to generate and send error reports.
User Interface Enhancements:
Streamlined and more intuitive user interface for submitting error reports.
Added clearer instructions and feedback during the error reporting process to guide users.
Security Enhancements:
Improved security features to ensure that error reports are transmitted securely.
Enhanced data privacy measures to protect user information during the error reporting process.
Bug Fixes:
Resolved several minor defects that were discovered in previous versions.
Improved stability and reliability of the error reporting service.
Please refer to the below link for more details
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Error-Reporting.ht...
brian.strandberg
I don't know why they didn't post this information in the release notes.  I have often had questions about software updates.  Thanks.
