Autodesk Application Manager
If I start up my computer (windows 10) I receive this message:
"Do you allow the following program to make changes to your computer?
Program: Autodesk Component
Publisher: Autodesk Inc."
This message appears everytime I start up the computer. I can choose between the options YES and NO. I tried both options, but nothing changes.
Reinstalling the Autodesk Application Manager does not solve this problem, the message still appears. How can I remove this message?
Before I had this issue, I changed the proporties of the Application Manager. I'm running it as an admin. If I reset the proporties I receive this error message:
"Unable to run AAM. It appears AAM service is not available. Please close all instances and retry."
BJ.C
Hi arpinegix,
My first suspicion is that the Application Manager was not installed within an account with administrator rights.
You can try this fix at the following link:
http://www.techsupportalert.com/content/how-create-program-shortcut-run-without-uac-prompt-windows-7...
Otherwise I would try uninstalling/reinstalling with a user that has administrator rights privileges.
BJ.C
Technical Support Specialist
