Autodesk Account Deployment Creator help details
BIMologist_
Message 1 of 1
BIMologist_
Hi
Running into the classic tech help document issue of a description of the item and no further details. Would appreciate if someone can shed some light on the details of the two XML files for me.
https://help.autodesk.com/view/ACD/2022/ENU/?guid=modify_odis_deployment
Deployment Configuration - o <file path> Specifies the file path of the deployment configuration to be loaded for this installation. Generally, this should be the deployment.xml file in the image folder.
Bundle Extension -- extension_manifest <file path> Specifies the file path of the manifest that includes updates, extensions, plugins, content, and language packs to be included in this installation.
Can someone please explain the make up and details of the deployment.xml and the or the configuration of the manifest files?
trying to add custom installer for plugins
thanks
BIMologist
- Nauman Mysorewala
Did you find this post
helpful? Feel free to like this post.
Did your question get successfully answered? Then click
on the ACCEPT SOLUTION button.
Replies (0)
