AutoCAD LT 2013 Immediate Shutdown After Loading
I am experiencing an issue with my AutoCAD LT 2013, to where after the screen, the software immediately shuts down. To explain the situation, I have a the program installed on two PCs (one at the office, one personal at home), I am told that this is acceptable with my license type as long as they are not used simultaneously. The program worked for a time on my home PC until this current issue, I am having no issues on the office PC. I have already tried resetting to default settings, as well as remove and reinstall completely on my home PC. The error code readout I have is as follows:
8156 2017/08/02 18:03:52 Reason=Fatal error
8156 2017/08/02 18:03:52 ComputerName=DESKTOP-OTTTLC1
8156 2017/08/02 18:03:52 OS=6.2.9200.
8156 2017/08/02 18:03:52 File=AdlmFlxActTS.cpp,Line=784
8156 2017/08/02 18:03:52 AdlmActError=102 [Too many licenses of one type]
8156 2017/08/02 18:03:52 File=AdlmFlxActAppTrialAndConfigLicenseHandler.cpp,Line=243
8156 2017/08/02 18:03:52 AdlmActError=1 [Internal or programming error]
13656 2017/08/02 18:03:52 Reason=Fatal error
13656 2017/08/02 18:03:52 ComputerName=DESKTOP-OTTTLC1
13656 2017/08/02 18:03:52 OS=6.2.9200.
13656 2017/08/02 18:03:52 File=AdlmIntSATSLicense.cpp,Line=467
13656 2017/08/02 18:03:52 VendorID=2 [ADLMACT]
13656 2017/08/02 18:03:52 VendorError=1 [Internal or programming error]
I spoke with customer service they said they could not help because my version of the program is too old. PLEASE HELP, THIS IS A HUGE HINDRANCE ON MY WORK.
PC Info is as follows:
Processor                 Intel(R) Core(TM) i5-6600K CPU @ 3.50GHz
RAM                       16 GB
Video Card              NVIDIA GeForce GTX 1070
Driver Version          22.21.13.8494
Operating System    Microsoft Windows 10 (build 15063), 64-bit
I even tried backdating my Video Card Driver Version, as I thought that might have something to do with it, it did not work either. Wondering if some hidden windows update might be causing the issue.
braudpat
Hello
Welcome to the Autodesk / AutoCAD Forums !
1) As you must know ACAD version 20XX-2014 (even 2015 is not guaranted) is not at all supported on Windows 10
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/Windows-...
2) You could try to update your ACAD LT 2013 shortcut with the option  /NOHARDWARE   !?
Clic on the shortcut
Right Button
At the END the Target Filed, please add the option:
  /NOHARDWARE
With at least ONE blank/space before writing  /NOHARDWARE
3) Have you updated your ACAD LT 2013 with the SP2 ?
https://knowledge.autodesk.com/support/autocad-lt/downloads/caas/downloads/content/autocad-lt-2013-s...
Regards, Patrice
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
pendean
Community Legend
Community Legend
