AutoCAD LT 2012 with product key 057D1 - Installation issue on 64-bit Windows OS
I have an AutoCAD LT 2012 with product key 057D1. I am facing problem in installing the same in my 64 bit Windows Operating system. Is this version compatible with 64 bit OS and how to deal with the error while installing in 64 bit OS.
Regards
Sumeet Kureel
Otto
Hello skureel and welcome to the Autodesk community!
It looks like you need to find out more about downloading or re-downloading software, or are having issues that may be resolved by re-downloading.
For Windows users, before downloading products on Windows 10, please check that the product is compatible.
For general information about downloading or re-downloading (including eligibility), Community members with similar questions found the following article(s) useful:
Download Finder
Previous Versions of Autodesk Software
Download Methods
Find Your Eligibility for Previous Versions of Autodesk Software
Oftentimes installation and/or download issues can be addressed by using a different download method, or by downloading directly from the Autodesk Virtual Agent. Community members with similar issues found the following article(s) useful:
Software & Downloads
Downloading Previous Versions of Autodesk Software Using the Virtual Agent (Please be sure to disable your firewall and anti-virus before downloading)
Performing a Clean Uninstall
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
Darin.Green
@Anonymous
You would need the 64bit media. Unfortunately, unless you can get it from you Autodesk Account or have the dvd's, there's no way of getting access to it. Why not upgrade to a newer version?
If this information was helpful, please consider using the Accept Solution
