AutoCad activation 2019
I am having trouble activating the AutoCad 2019, I recently purchased the independent license and when I put the serial and key the button to enable does not enable.
Mark.Lancaster
@Anonymous
Welcome to the Autodesk User's Community..
Can you provide the screen shot of what you're seeing?   Make sure to remove your serial # info before posting.
Also were you issued a serial #?  Did you obtain this product through the e-store?  Is this a student or commercial license?
Mark Lancaster
natasha.l
Hello @Anonymous,
Welcome.
I see you have a single-user subscription for AutoCAD, be sure to locate your serial number & product key from your Autodesk Account. Be sure the Serial Number you are using matches the product installer title & product version.
To activate a subscription license:
  1. Locate the activation method in your Autodesk Account, it will state either, "Sign-in" or provide a "Serial Number & Product Key"
    • Please type the Serial Number & Product Key do not copy/paste
  2. An internet connection is required to activate & every 30 days you should be connected to the internet at some point (to verify your license & use the software)
  3. Adjust your proxy settings, to allow access during the install & first launch, also make sure you have an uninterrupted connection or try a different secured network, access a different Wifi connection
You can contact registration & activation for more in-depth support.
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
Good morning, follow the screen I put the serial plus the button to activate does not enable ...
Mark.Lancaster
@Anonymous
Are you the contract manager or software coordinator for your subscription?  If not has those individuals created a user account under their subscription and assigned the use of the product to that user?
Mark Lancaster
