AutoCAD 2024, Install error 1
MattH_Work
Advisor Advisor
MattH_Work
Not a particularly auspicious start...
Download
Move to 'Software Download' location (NOT my downloads folder)
Install
Gets to 6%, rolls back, Error 1
Download again
Keep in default location
Install
Search for a solution
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Install-error-The-...
"Change the default locations of the TEMP folders
  1. Search for "Edit the system environment variables" in the Windows search bar.
  2. In the System Properties window, select the button for "Environment Variables...".
  3. In the User variables section for the current profile verify the default locations for the Variables "Temp" and "TMP" are set to the default location (and select the "Edit" button to change the "Variable value" if the variables are not set for the default location): C:\Users\%userprofile%\AppData\Local\Temp"
Why Oh Why would it matter where the TMP folders are, just use MY Temp folders!!!
MattH
Product Design Collection 2026
Vault Pro 2026
vladimir_michl
Did you participate in the Beta program? If so, uninstall your beta versions as instructed.
Vladimir Michl, www.arkance-systems.cz  -  www.cadforum.cz
MattH_Work
No Beta install this year
Changing back to 'Default' TMP & TEMP folders allowed the install to continue
I just feel that this is another example of the Installers continuous and unneeded 'dumb down'
MattH
Vault Pro 2026
mdavis22569
Try my offline installer from
https://forums.autodesk.com/t5/installation-licensing/2024-product-download-links/m-p/11835996/highl...
Make sure you have the admin rights / Anti-Virus off
Mike Davis
