AutoCAD 2021 - SCCM install fails after 2 hours during OSD task.
These are the instructions included with AutoCAD 2021 deployment:
In most cases, Autodesk deployments can now be advertised using a single program line instead of individual program lines for each component in the deployment.
To advertise a deployment with a single program line, use the following syntax:
.\Img\Setup.exe /W /Q /I .\Img\<deployment name>.ini /language en-us
This sample command line assumes that the package contents are defined at the root folder of your Autodesk product deployment folder, and that the product language is US English (en-us).
So I made a package and used the above (with the correct ini) as the command line. But either it is hanging or it is installing so slowly that it times out at 2 hours. Error 1603, 80070103, 80070643. All too generic, no sccm logs give any indication of what the problem is, and as it's installing during OSD, I don't know where the log files are going to be for the installer.
Please note I'm installing several Autodesk apps one at a time, 3DSMax 2021, AutoCad 2021, Inventor 2021, Revit 2021, then Maya 2020. If this doesn't work due to some overlapping in support programs or the auto desk desktop app, help me do it correctly.
Thanks.
Are these the right instructions or should it be differently or outside of a package?
