AutoCAD 2017 Has Broken Everything
Kyudos
Advisor Advisor
Kyudos
I'm on a Windows 7 64-bit. I had AutoCAD 2016 installed and working fine. The AutoDesk updater app popped up and asked if I wanted to install AutoCAD 2017. Sure I thought, I'll check it out.
Immediately after 2017 was installed BOTH installations were then broken - both apps would immediately crash on start up. So that isn't a good look for AutoDesk to start with, but whatever.
I uninstalled 2017, 2016 is still broken.
I uninstalled 2016.
I tried to re-install 2016, but it won't install. During the install Iget several of these:
"A newer version of this application is already installed on this computer. If you wish to install this version, please uninstall the nerwer version first. Click OK to exit the wizard."
The final installer dialog says everything except the BIM 360 add-in failed to install and I'm left with the same APPCRASH I had originally after installing 2017
Crash says:
Problem signature:
  Problem Event Name:	APPCRASH
  Application Name:	acad.exe
  Application Version:	26.1.49.0
  Application Timestamp:	54d44341
  Fault Module Name:	accore.dll
  Fault Module Version:	20.1.49.0
  Fault Module Timestamp:	54d4450b
  Exception Code:	c0000005
  Exception Offset:	000000000009d430
  OS Version:	6.1.7601.2.1.0.256.4
  Locale ID:	5129
  Additional Information 1:	9524
  Additional Information 2:	95245ee7c48d5631f2c536e2f084c397
  Additional Information 3:	a63c
  Additional Information 4:	a63ca6497d79b3be0a7beb5a3b005989
Read our privacy statement online:
  http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409
If the online privacy statement is not available, please read our privacy statement offline:
  C:\Windows\system32\en-US\erofflps.txt
Log file says:
2016/7/28:10:00:02	crosbyd	91374-CROSBYD	=== Setup started on 91374-CROSBYD by crosbyd ===
2016/7/28:10:00:02	crosbyd	91374-CROSBYD	Path_Length: 154
2016/7/28:10:00:02	crosbyd	91374-CROSBYD	Current Directory C:\Autodesk\AutoCAD_2016_English_Win_32_64bit_wi_en-us
2016/7/28:10:00:02	crosbyd	91374-CROSBYD	Launch
2016/7/28:10:00:02	crosbyd	91374-CROSBYD	CommandLine	/URL "http://efulfillment.autodesk.com/NET16SWDLD/2016/ACD/WI/AutoCAD_2016_English_Win_32_64bit_wi_en-us_Setup.exe?authparam=b91ba1b191a933c9c10b81c98913132b812b1b811b991b3389b98913a1c933b9&SESSION_ID=a1b3A00000040URQAY" /skipPI /akamai
2016/7/28:10:00:02	crosbyd	91374-CROSBYD	Current Directory C:\Temp\_AIF5A5.tmp
2016/7/28:10:00:04	crosbyd	91374-CROSBYD	=== Setup ended ===
2016/7/28:10:00:03	crosbyd	91374-CROSBYD	=== Setup started on 91374-CROSBYD by crosbyd ===
2016/7/28:10:00:03	crosbyd	91374-CROSBYD	Path_Length: 154
2016/7/28:10:00:03	crosbyd	91374-CROSBYD	Current Directory C:\Temp\_AIF5A5.tmp
2016/7/28:10:00:03	crosbyd	91374-CROSBYD	Launch
2016/7/28:10:00:03	crosbyd	91374-CROSBYD	Download	Skipped	SETUPMARKER	http://efulfillment.autodesk.com/NET16SWDLD/2016/ACD/WI/{863FECAF-D44B-46FF-931D-4710220A9794}/SETUPMARKER_x64.tar.lzma2?authparam=1465604326_0aa5da25b05d4aff792e07e4aa2550e1
2016/7/28:10:00:04	crosbyd	91374-CROSBYD	Download	Skipped	SETUP_CONFIG	http://efulfillment.autodesk.com/NET16SWDLD/2016/ACD/WI/{863FECAF-D44B-46FF-931D-4710220A9794}/SETUP_x64.tar.lzma2?authparam=1465604326_550d4055fa3366b8b355094793cf7c9f
2016/7/28:10:00:04	crosbyd	91374-CROSBYD	Install	CustomCallback	Info	Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Temp\_AIF5A5.tmp\Setup\AcSetup.dll
2016/7/28:10:00:04	crosbyd	91374-CROSBYD	Install	CustomCallback	Info	Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2016/7/28:10:00:04	crosbyd	91374-CROSBYD	PageOpen	LaunchDialog
2016/7/28:10:00:07	crosbyd	91374-CROSBYD	PageOpen	LicenseDialog
2016/7/28:10:00:10	crosbyd	91374-CROSBYD	PageOpen	ProductInfoDialog
2016/7/28:10:00:30	crosbyd	91374-CROSBYD	PageOpen	ProductSelectionDialog2
2016/7/28:10:01:19	crosbyd	91374-CROSBYD	PageOpen	FullProgressDialog
2016/7/28:10:01:20	crosbyd	91374-CROSBYD	Download	Skipped	STARTMARKER	http://efulfillment.autodesk.com/NET16SWDLD/2016/ACD/WI/{863FECAF-D44B-46FF-931D-4710220A9794}/STARTMARKER_x64.tar.lzma2?authparam=1465604945_527c43be5d017976ce7df2aff41a44b6
2016/7/28:10:01:20	crosbyd	91374-CROSBYD	Download	Skipped	DIRECTX	http://efulfillment.autodesk.com/NET16SWDLD/2016/ACD/WI/{863FECAF-D44B-46FF-931D-4710220A9794}/DIRECTX.tar.lzma2?authparam=1465604946_d75899012144f639067eb656fed3fe71
2016/7/28:10:01:20	crosbyd	91374-CROSBYD	Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2016\3rdParty\DirectX\DXSETUP.exe" /silent
2016/7/28:10:01:29	crosbyd	91374-CROSBYD	Install	DirectX Runtime	Succeeded
2016/7/28:10:01:29	crosbyd	91374-CROSBYD	Download	Skipped	CM	http://efulfillment.autodesk.com/NET16SWDLD/2016/ACD/WI/{863FECAF-D44B-46FF-931D-4710220A9794}/CM.tar.lzma2?authparam=1465604963_107ab2fe2778fae011650418efb77bdc
2016/7/28:10:01:29	crosbyd	91374-CROSBYD	Installing Autodesk Material Library 2016:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2016" SETUP_PACKAGECODE={95CB8CCB-26D5-4C61-8F34-C6D922AB0D3C} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={F0736EFA-A11E-42C4-83B9-243BF2E8D69A} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2016/7/28:10:01:37	crosbyd	91374-CROSBYD	Install	Autodesk Material Library 2016	Succeeded
2016/7/28:10:01:37	crosbyd	91374-CROSBYD	Download	Skipped	CMILB	http://efulfillment.autodesk.com/NET16SWDLD/2016/ACD/WI/{863FECAF-D44B-46FF-931D-4710220A9794}/CMILB.tar.lzma2?authparam=1465604982_cb47fefefc61a9880bd84964a3091ed8
2016/7/28:10:01:37	crosbyd	91374-CROSBYD	Installing Autodesk Material Library 2016 - Base Image Library:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2016" SETUP_PACKAGECODE={95CB8CCB-26D5-4C61-8F34-C6D922AB0D3C} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={F0736EFA-A11E-42C4-83B9-243BF2E8D69A} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2016/7/28:10:01:44	crosbyd	91374-CROSBYD	Install	Autodesk Material Library 2016 - Base Image Library	Succeeded
2016/7/28:10:01:44	crosbyd	91374-CROSBYD	Download	Skipped	CMAIL	http://efulfillment.autodesk.com/NET16SWDLD/2016/ACD/WI/{863FECAF-D44B-46FF-931D-4710220A9794}/CMAIL.tar.lzma2?authparam=1465604997_0893f35d814f1fe1a62d713d982d7499
2016/7/28:10:01:44	crosbyd	91374-CROSBYD	Installing Autodesk® Material Library 2016 - Advanced Image Library:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2016" SETUP_PACKAGECODE={95CB8CCB-26D5-4C61-8F34-C6D922AB0D3C} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{29A7D6EC-63C2-42FD-8143-5812ABD2923F},;;;;" PACKAGEUPI={F0736EFA-A11E-42C4-83B9-243BF2E8D69A} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2016/7/28:10:01:46	crosbyd	91374-CROSBYD	Install	Autodesk® Material Library 2016 - Advanced Image Library	Succeeded
2016/7/28:10:01:47	crosbyd	91374-CROSBYD	Installing Autodesk Content Service:  INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Autodesk\WI\Autodesk AutoCAD 2016\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2016" SETUP_PACKAGECODE={95CB8CCB-26D5-4C61-8F34-C6D922AB0D3C} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=".NET Framework Runtime 4.5,Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x86),;;;;" PACKAGEUPI={F0736EFA-A11E-42C4-83B9-243BF2E8D69A} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2016/7/28:10:01:50	crosbyd	91374-CROSBYD	Install	Autodesk Content Service	Succeeded
2016/7/28:10:01:50	crosbyd	91374-CROSBYD	Installing Autodesk Content Service Language Pack:  ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2016" SETUP_PACKAGECODE={95CB8CCB-26D5-4C61-8F34-C6D922AB0D3C} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={F0736EFA-A11E-42C4-83B9-243BF2E8D69A} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2016/7/28:10:01:51	crosbyd	91374-CROSBYD	Install	Autodesk Content Service Language Pack	Succeeded
2016/7/28:10:01:51	crosbyd	91374-CROSBYD	Download	Skipped	ACAD	http://efulfillment.autodesk.com/NET16SWDLD/2016/ACD/WI/{863FECAF-D44B-46FF-931D-4710220A9794}/ACAD_x64.tar.lzma2?authparam=1465605014_5a3bddc83509c5f796632f4a6764b889
2016/7/28:10:01:51	crosbyd	91374-CROSBYD	Installing AutoCAD 2016 Core:   TRANSFORMS="C:\Temp\_AIF5A5.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2016" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2016\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2016/7/28:10:04:06	crosbyd	91374-CROSBYD	Install	AutoCAD 2016 Core	Succeeded
2016/7/28:10:04:06	crosbyd	91374-CROSBYD	Download	Skipped	ACAD_LP	http://efulfillment.autodesk.com/NET16SWDLD/2016/ACD/WI/{863FECAF-D44B-46FF-931D-4710220A9794}/ACAD_LP_x64_en-US.tar.lzma2?authparam=1465605224_4f365f0e026938922bceaece4e249d52
2016/7/28:10:04:06	crosbyd	91374-CROSBYD	Installing AutoCAD 2016 Language Core:   TRANSFORMS="C:\Temp\_AIF5A5.tmp\x64\en-us\acad\AcadLP\AcadLP-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2016" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2016\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2016/7/28:10:04:19	crosbyd	91374-CROSBYD	Install	AutoCAD 2016 Language Core	Succeeded
2016/7/28:10:04:19	crosbyd	91374-CROSBYD	Download	Skipped	ACAOE	http://efulfillment.autodesk.com/NET16SWDLD/2016/ACD/WI/{863FECAF-D44B-46FF-931D-4710220A9794}/ACAOE_x64.tar.lzma2?authparam=1465605261_f74926342fb4f747351615de2d7c6f2f
2016/7/28:10:04:19	crosbyd	91374-CROSBYD	Installing ACA & MEP 2016 Object Enabler:   TRANSFORMS="C:\Temp\_AIF5A5.tmp\x64\ACAOE\AcaOE-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2016" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2016\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2016/7/28:10:04:22	crosbyd	91374-CROSBYD	Install	ACA & MEP 2016 Object Enabler	Succeeded
2016/7/28:10:04:22	crosbyd	91374-CROSBYD	Download	Skipped	ACADPV	http://efulfillment.autodesk.com/NET16SWDLD/2016/ACD/WI/{863FECAF-D44B-46FF-931D-4710220A9794}/ACADPV_x64.tar.lzma2?authparam=1465605275_ea709be939ec547b957fb13c3328ccae
2016/7/28:10:04:22	crosbyd	91374-CROSBYD	Installing AutoCAD 2016:   TRANSFORMS="C:\Temp\_AIF5A5.tmp\x64\ACADPRIVATE\AcadPrivate-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2016" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2016\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2016/7/28:10:04:25	crosbyd	91374-CROSBYD	Install	AutoCAD 2016	Succeeded
2016/7/28:10:04:25	crosbyd	91374-CROSBYD	Download	Skipped	ACAD_MAIN	http://efulfillment.autodesk.com/NET16SWDLD/2016/ACD/WI/{863FECAF-D44B-46FF-931D-4710220A9794}/ACAD_MAIN_x64_en-US.tar.lzma2?authparam=1465605290_3c84af9984d984858b5105e74d6611bf
2016/7/28:10:04:25	crosbyd	91374-CROSBYD	Installing Autodesk® AutoCAD® 2016:  TRANSFORMS="C:\Temp\_AIF5A5.tmp\x64\en-us\acad\AcadPS\AcadPS-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2016" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2016\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2016/7/28:10:04:44	crosbyd	91374-CROSBYD	Install	Autodesk® AutoCAD® 2016	Succeeded
2016/7/28:10:04:44	crosbyd	91374-CROSBYD	Installing SketchUp Import plug-in:  ADLANGUAGE=en-us ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2016" SETUP_PACKAGECODE={95CB8CCB-26D5-4C61-8F34-C6D922AB0D3C} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={F0736EFA-A11E-42C4-83B9-243BF2E8D69A} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2016/7/28:10:06:35	crosbyd	91374-CROSBYD	Install	SketchUp Import plug-in	Failed	Failure is ignored, Result=1603
2016/7/28:10:06:35	crosbyd	91374-CROSBYD	Installing Exchange App Manager:  ADLANGUAGE=en-us ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2016" SETUP_PACKAGECODE={95CB8CCB-26D5-4C61-8F34-C6D922AB0D3C} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={F0736EFA-A11E-42C4-83B9-243BF2E8D69A} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2016/7/28:10:06:37	crosbyd	91374-CROSBYD	Install	Exchange App Manager	Failed	Failure is ignored, Result=1603
2016/7/28:10:06:37	crosbyd	91374-CROSBYD	Installing Exchange Featured Apps plug-in:  ADLANGUAGE=en-us ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2016" SETUP_PACKAGECODE={95CB8CCB-26D5-4C61-8F34-C6D922AB0D3C} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={F0736EFA-A11E-42C4-83B9-243BF2E8D69A} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2016/7/28:10:06:37	crosbyd	91374-CROSBYD	Install	Exchange Featured Apps plug-in	Failed	Failure is ignored, Result=1603
2016/7/28:10:06:37	crosbyd	91374-CROSBYD	Installing Autodesk® AutoCAD® Performance Reporting Tool:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2016" SETUP_PACKAGECODE={95CB8CCB-26D5-4C61-8F34-C6D922AB0D3C} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={F0736EFA-A11E-42C4-83B9-243BF2E8D69A} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2016/7/28:10:06:39	crosbyd	91374-CROSBYD	Install	Autodesk® AutoCAD® Performance Reporting Tool	Failed	Failure is ignored, Result=1603
2016/7/28:10:06:39	crosbyd	91374-CROSBYD	Installing Autodesk® BIM 360™ Add-in for AutoCAD® 2016:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2016" SETUP_PACKAGECODE={95CB8CCB-26D5-4C61-8F34-C6D922AB0D3C} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={F0736EFA-A11E-42C4-83B9-243BF2E8D69A} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2016/7/28:10:06:39	crosbyd	91374-CROSBYD	Install	Autodesk® BIM 360™ Add-in for AutoCAD® 2016	Succeeded
2016/7/28:10:06:39	crosbyd	91374-CROSBYD	Download	Skipped	SUCCESSMARKER	http://efulfillment.autodesk.com/NET16SWDLD/2016/ACD/WI/{863FECAF-D44B-46FF-931D-4710220A9794}/SUCCESSMARKER_x64.tar.lzma2?authparam=1465605371_4886422c55e5223c248d2d1f2afb0265
To say I'm less than impressed is an understatement. How do I get back to a working install?
Accepted solutions (3)
Darin.Green
Download the software from the Autodesk Virtual Agent
Once there, use the Download Links option to navigate to the application you need to download.
NOTE: If there are multiple parts for the download, you'll need to click each part to download them, one they are downloaded double-click Part1 (which will automatically extract the remaining parts) to begin the installation.
If this information was helpful, please consider using the Accept Solution
Kyudos
The standalone install doesn't help. It all looks like its working but I still get the 'earlier version' messages and I still end up with this:
Failed to Install
Mark.Lancaster
@Kyudos
It sounds like you have stuff left over...  Did you perform a clean uninstall per this article and then use Microsoft Fixit (link in my signature) to remove any left over items related to Autodesk products.
Mark Lancaster
asburyj
Hi Kyudos,
Sorry that you're running into trouble. For the isntall i would suggest a clean uninstall (https://knowledge.autodesk.com/customer-service/installation-activation-licensing/get-ready/remove-p...) and then re-install from that 2016 full installer you have downloaded.
In regards to the app crash, if the 2017 install caused 2016 to crash. My suspicion is that the 2017 installer likely updated a windows component such as microsoft.net frame work or visual c++ or direct X, that in turn may be causing an incompatibility with the video driver. There are two options That should get you working if the first doesn't work please try the second.
Option 1: Update your video driver to the latest version available from your video card manufacturer. Typically you can find this on the video card manufacture's website such as www.nvidia.com
Options 2: Roll back the changes to your system. If option 1 didn't help or there are no newer drivers available try using the windows restore option to revert your windows to a restore point prior to the AutoCAD 2017 install. This should also reverse any of the windows component updates that were done as part of the install.
  1. From the Start menu, type: Restore in the Search programs and files dialog box.
  2. From the list of results, click System Restore.
  3. In the System Restore window, click Next.
  4. From the list of restore points, select the Date and Time you wish to restore from.
Jeffry Asbury
Kyudos
So it seems that may have been the culprit. I was using AutoCAD's uninstaller.
I uninstalled using the Windows system and removed the left over directories.
The 2016 install now works...I think I'll just avoid 2017 for now (I'm developing for 2016).
The question remains though - why provide an uninstaller if it doesn't work and you don't recommend using it?
asburyj
Typically the Autodesk uninstall utility works just as well as the windows uninstaller and adds the additional functionality of letting to uninstall multiple Autodesk products at once. Clearly something didn't work in this case which is why the manual removal of files was needed. Let us know if you encounter anything else strange and we'll be happy to help.
Jeffry Asbury
