AutoCAD 2016 Failed Installation - Windows 10
Please help me with the installation of AUTOCAD 2016 on Windows 10 (64 bit)
The installation log file says:
2016/9/30:02:54:27 manue LAPTOP-IVVQQGBU === Setup started on LAPTOP-IVVQQGBU by manue ===
2016/9/30:02:54:27 manue LAPTOP-IVVQQGBU Path_Length: 154
2016/9/30:02:54:27 manue LAPTOP-IVVQQGBU Current Directory C:\Users\manue\AppData\Local\Temp\_AICBC3.tmp
2016/9/30:02:54:27 manue LAPTOP-IVVQQGBU Launch
2016/9/30:02:54:28 manue LAPTOP-IVVQQGBU Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/SETUPMARK...
2016/9/30:02:54:28 manue LAPTOP-IVVQQGBU Download Play SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/SETUP_x64...
2016/9/30:02:55:56 manue LAPTOP-IVVQQGBU Download Complete SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/SETUP_x64...
2016/9/30:02:55:56 manue LAPTOP-IVVQQGBU Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\manue\AppData\Local\Temp\_AICBC3.tmp\Setup\AcSetup.dll
2016/9/30:02:55:56 manue LAPTOP-IVVQQGBU Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2016/9/30:02:55:57 manue LAPTOP-IVVQQGBU PageOpen LaunchDialog
2016/9/30:02:56:16 manue LAPTOP-IVVQQGBU PageOpen LicenseDialog
2016/9/30:02:56:16 manue LAPTOP-IVVQQGBU PageOpen ProductInfoDialog
2016/9/30:02:56:16 manue LAPTOP-IVVQQGBU PageOpen ProductSelectionDialog2
2016/9/30:02:56:24 manue LAPTOP-IVVQQGBU PageOpen FullProgressDialog
2016/9/30:02:56:25 manue LAPTOP-IVVQQGBU Download Play STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/STARTMARK...
2016/9/30:02:56:25 manue LAPTOP-IVVQQGBU Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/STARTMARK...
2016/9/30:02:56:25 manue LAPTOP-IVVQQGBU Download Play DIRECTX http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/DIRECTX.t...
2016/9/30:02:56:37 manue LAPTOP-IVVQQGBU Download Complete DIRECTX http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/DIRECTX.t...
2016/9/30:02:56:37 manue LAPTOP-IVVQQGBU Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2016\3rdParty\DirectX\DXSETUP.exe" /silent
2016/9/30:02:56:52 manue LAPTOP-IVVQQGBU Install DirectX Runtime Succeeded
2016/9/30:02:56:52 manue LAPTOP-IVVQQGBU Download Play CM http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/CM.tar.lz...
2016/9/30:02:57:32 manue LAPTOP-IVVQQGBU Download Aborted CM http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/CM.tar.lz...
2016/9/30:02:57:32 manue LAPTOP-IVVQQGBU Install Autodesk Material Library 2016 Failed Download Failed, Installation aborted, Result=1603
2016/9/30:02:57:32 manue LAPTOP-IVVQQGBU Rollback DirectX Runtime Failed Failure is ignored, Result=1619
I have tried many times, i have no idea what to do.
Please!
Darin.Green
This is an issue with the web installer...
Download the software from the Autodesk Virtual Agent
Once there, use the Download Links option to navigate to the application you need to download.
NOTE: If there are multiple parts for the download, you'll need to click each part to download them, once they are downloaded double-click Part1 (which will automatically extract the remaining parts) to begin the installation.
If this information was helpful, please consider using the Accept Solution
