Autocad 2013 64 bit installer required.
Hi. I recently upgraded and I now require a 64 installer to run AutoCAD 2013.  Where can I download or what should I do.
swieciakpawel
Hello and Welcome to Autodesk Forums,
Please go to Autodesk Virtual Agent
While on this website, go to:
- Download Links -> AutoCAD Products -> AutoCAD
There will be located a 64bit installer for the AutoCAD 2013 product You're looking for.
Kind Regards,
Pawel
Mark.Lancaster
@Anonymous
Welcome to the community...
Upgraded to what?  Operating system?  What version?  If its Windows 10, AutoCAD 2013 is not supported under that OS.  Not saying it will not work but you could run into issues and/or it fails to install.  Also just becuase you have AutoCAD 2013, doesn't mean the serial # is active anymore.  It all depends on the history of your information.   Also 2013 is retired and no longer supported by Autodesk.
Mark Lancaster
natasha.l
Hello @Anonymous,
As mentioned above with your new 64bit system you can download your software and use the browser download method via the Autodesk Virtual Agent. Please review the system requirements to make sure it is supported.
  • Log in as an Administrator
  • Empty your TEMP folder. To open the TEMP folder, type %TEMP% in the address bar of Windows Explorer and hit Enter
  • Temporarily disable your Antivirus software & Firewall
  • Temporarily disable UAC:  Windows 7Windows 10
  • Download all of the parts Autodesk Virtual Agent
  • Locate the download folder and extract (double click) part _001_00X.sfx.exe. If you have a permission issue right click and select, Run as administrator
  • Files will be directed to C:\Autodesk
  • Follow the prompts to install the program
natasha.l
Hello @akashr1zn,
I hope the suggestions provided resolved the issue for you. Please report back with an update on the progress. Thanks. Smiley Happy
Hello, I have purchased  mudbox 2012 and 2013, the two ones, but it doesnt open im in windows 10,
i have  INtel HD Graphic 6000,but there are comments i need anoter graphics card, but that problem are resolved in mudbox 2014,
i need to download that, can i use the same key?
Mark.Lancaster
@Anonymous
First thing..  Don't hi-jack another posting and change the subject to suit your needs.   Just make a new posting.
When did you purchase Mudbox 2012 and 2013?  These are obsolete/retired and unsupported products and they will not work on Windows 10..  And just because you have these legacy version doesn't mean you are entitled to get another version free of charge.  Each product and version have their own serial # and product key.  So any information you have for 2012 and/or 2013 will not work for 2014.
Mark Lancaster
