Auto CAD error: Unhandled exception e06d7363 (e06d7363h) at address ab9fa388h
Message 1 of 30
Hi!
I have installed AutoCAD 2019 on my laptop and when I first started the program a pop up window showed the message that the AutoCAD was not installed correctly, and after that it showed me this errors:
      -  Unhandled exception e06d7363 (e06d7363h) at address ab9fa388h
      -  Unhandled exception c000005 access violation reading 0x0060 at address 5249b22fh
I can run AutoCAD and open DWG files on it, but every time I start te AutoCAD this error messages show up, and after few minutes the AutoCAD crashes.
I have tried reinstalling the AutoCAD, but it didn't helped. The same errors showed up again after the reinstallation.
Then I uninstalled the AutoCAD and installed Autodesk TrueView.
TrueView was working fine with most DWG files. But sometimes it crashes when opening some DWG files, and then showed me this error: FATAL ERROR: Unhandled access violation reading 0X0031 exception at 665aee95h
I have Dell 5570 laptop with Windows 10 64bit, Core i7, 16GB RAM, AMD Radeon graphic card
I couldn't find any solution on internet for my problem. Can you please help me.
Replies (29)
Message 21 of 30
TAR_Loki
How can I find this option under Windows 10?
Message 22 of 30
It's under Settings > Time & Language
Or just type "Region settings" into the Windows search bar:
Message 23 of 30
TAR_Loki
Windows 10 wn' offer me that option:
Can I find it everywhere else?
Message 24 of 30
Alfred.NESWADBA
Seems to be an older version of Windows 10.
The option "Beta: Unicode .... " was introduced with 1803 I guess (not sure, could be 1903 too).
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 25 of 30
I have the same messge ( Unhandled exception e06d7363 ) for cad 2020 & 2019  and same lap top device
dell 5570
Message 26 of 30
I tried this methods that you mentioned, but it didn't helped.
Message 27 of 30
Thank you very much.
Message 28 of 30
problem solved. Thx
Message 29 of 30
TvXDxuandat2015
Observer
Observer
Message 30 of 30
TvXDxuandat2015
Observer
Observer
