Announcements
attempt to reset AutoCAD to default settings made AutoCAD unusable, even after reinstallation
pharperM724X
pharperM724X
Hi, the short version of this is that I attempted to do a simple thing, following Autodesk's instructions precisely, and now I can't open AutoCAD.
The long version:
I was having trouble with a new block. Its text attribute was not appearing. I found the instructions on this page and followed them in order, except the part about fixing a corrupt file. I got to the part about fixing a corrupt user profile and decided to try that. It said I should reset AutoCAD to its factory defaults. The instructions seemed straightforward so I tried that. I made sure to choose the option "Back up and Reset Settings", so I could undo the operation if necessary.
After I ran the Reset procedure, I got an IE window with the log. It contained many errors. Please see the attached file. I tried to open AutoCAD anyway and got this message:
Configuration file may be locked by another process or have been set Read Only(.cfg, .bak).
File: C:\Program Files\Autodesk\AutoCAD 2023\acad2023.cfg
Please correct this problem and press Retry or press Cancel to exit the application.
I looked, and there is no acad2023.cfg file in the directory C:\Program Files\Autodesk\AutoCAD 2023\.
This obviously was no good, so I went to find the .zip file, so I could restore my original settings. I found it, but when I attempted to extract the zipped files, Windows told me that the file was invalid. It contains over 430,000KB, so there must be something there, but I can't access it.
I called our company's IT department and they thought the best bet would be to uninstall and reinstall AutoCAD. (This is a health care company and IT doesn't have much experience with AutoCAD.) So we uninstalled AutoCAD and reinstalled it. It still gives the same error when I try to open it. There is still no file named acad2023.cfg.
I tried running "Reset Settings to Default" again with my new installation. This time, it says
AutoCAD 2023 - English has not been run yet. There are no settings to reset.
Our IT department thought I might be able to copy an acad2023.cfg file from someone else, and just put it in the right spot, but so far I haven't been able to reach anyone else who uses AutoCAD. I am also not confident that that will work. I've lost a day of work due to this. Any help would be greatly appreciated!
mdavis22569
 Try doing a clean uninstall first
Download a full new installer.
Turn of the Anti-Virus
Run the installer as an ADMIN
Don't add  anything / migrate anything.  Test it all first.
Let us know the results of that.
Mike Davis
Simon_Weel
For this kind of problems, I created a script to 'reset' AutoCAD. It basically does two things; delete the registry key and delete the user profile. Maybe that will solve your problem too?
This script is for AutoCAD 2021:
@Anonymous off
echo:
echo All settings for AutoCAD 2021 will be deleted.
echo:
tasklist /FI "IMAGENAME eq acad.exe" | find /I /N "acad.exe"
if "%ERRORLEVEL%"=="0" goto inuse
reg delete "hkcu\Software\Autodesk\AutoCAD\R24.0" /f
rd /s /q "%appdata%\Autodesk\AutoCAD 2021"
cls
echo:
echo AutoCAD will be re-configured after starting.
echo:
goto end
:inuse
cls
echo:
echo AutoCAD is in use. Close AutoCAD and try again.
echo:
:end
pause
pharperM724X
I'm sorry to take so long replying to this. IT and I had such a hard time with it that I completely forgot about the forum.
We tried a clean install and that didn't go nearly as smoothly as expected. There were four Autodesk processes running and they stopped us from deleting all the files. We killed 3 of the processes but the 4th one, AdSSO, kept restarting itself. So we deleted all the files that we could delete, but there were maybe half a dozen files left (and the folders they were in).
We went ahead and did a fresh installation anyway. The IT guy refused to turn off the anti-virus, so I don't know if that would have helped. After the reinstall we restarted the computer. AutoCAD started, but still had errors. (don't remember which errors exactly, we did a lot of messing with it last week)
Our final resolution: the IT department sent me a new laptop and we installed AutoCAD on that. So, still no idea what was actually going on, or how to fix it.
Thanks for the advice anyway!
pharperM724X
Thank you for the script! I now have a fresh installation of AutoCAD on a new laptop, so I'm just not going to try anything unusual for the time being. I'll keep it in mind, though!
mdavis22569
No worries, glad you're up and going again.
Any of these you can pick for a solution and close this out?
Mike
Mike Davis
wizard_ettore
Thank you. I had a problem where AutoCAD 2025 installed itself corrupt, and to can't reset it because it has never run. I uninstalled and re-installed, but that didn't work. Instead of doing that again, I found your solution, took your script's intent, modified it for 2025, and off to the races: problem solved.
reg delete needs to be changed to R25.0
... and the AutoCAD 2025 folder was never created yet so I didn't have to do that part.
