Artcam 2018 Demo
Artcam 2018 Demo
brianne9SFZY
Message 1 of 8
Artcam 2018 Demo
brianne9SFZY
Hi
I have downloaded and installed ArtCAM_Standard_2018_ML_Win_64bit_dlm.sfx
I ran it as Administrator.
It appeared to install ok.
When I run it and click on Start a Trial, A window pops up with "You are not licensed to run this program on this machine"
Clicking OK ends the programme.
I clicked on Sign in with the same result.
Apart from License key and network there are no other clickable buttons.
Help please.
Brian
Replies (7)
Message 2 of 8
Mark.Lancaster
@brianne9SFZY
Welcome to the Autodesk User's Community..
Please note, C:\Programdata is a hidden folder and you may need to adjust your viewing settings.
What sub-folder structure do you have under this folder ​​C:\ProgramData\Autodesk\CLM\LGS?
Mark Lancaster
Message 3 of 8
brianne9SFZY
Hi Mark
The LGS folder is empty.
BTW, I got a message yesterday saying I am banned from the Forum for X,0000 seconds. What's that all about?
As far as i am aware I did nothing wrong.
Message 4 of 8
Mark.Lancaster
@brianne9SFZY
Create this sub-folder C:\ProgramData\Autodesk\CLM\LGS\A9BJ1_2018.0.0.F
Start Windows notepad and type _USER as shown.
Save the text file as LGS.DATA  Make sure it didn't get saved as LGS.DATA.TXT
Navigate to C:\Users\[username]\AppData\Roaming\Autodesk\ folder
Delete the ADUT folder and it's contents
Launch the application again, does it work?
@brianne9SFZY wrote:
Hi Mark
Well hopefully messing around with the license files will not get you banned again...  Just kidding..  Its a stupid message that pops up and don't worry about..  I was getting hit by it this morning as well and I wasn't even signed it..
Mark Lancaster
Message 5 of 8
brianne9SFZY
Thanks Mark
Followed your instructions ok.
There is NO ADUT folder in
Ran programe again, same message when I clicked Start Trial
Message 6 of 8
Mark.Lancaster
@brianne9SFZY
My bad..  Smiley Sad
I gave you the wrong product code folder information..  I gave you the product code for Premium Artcam and not the Standard versuib.  I should've paid attention to the information you provided in your original post.
Rename the folder C:\ProgramData\Autodesk\CLM\LGS\A9BJ1_2018.0.0.F to C:\ProgramData\Autodesk\CLM\LGS\A9CJ1_2018.0.0.F and try again.
Good luck and let us know if that resolved the issue.
Mark Lancaster
Message 7 of 8
brianne9SFZY
Yeeaay!!
Thanks Mark
The programme now opens. Fingers crossed, I will be trying it out later today.
Thanks again
Brian
Message 8 of 8
brianne9SFZY
Hi Mark
All went well yesterday, tried program and created a model.
Today when I try to run program and open model it comes up with error message.
"An Autodesk product failed to send the required value for SERIALNUM.
The error report sent to Autodesk may be incomplete"
When I click OK, the program closes.
I have sent error report but heard nothing back yet.
