All versions freeze on startup
GLDevco
Message 1 of 38
GLDevco
I've got a weird one - I have 2027 and 2026 on my computer, and even 2025.  When I start AutoCAD, either from the shortcut, opening a file from Explorer, or even from the NVIDIA app, the program freezes after a few seconds of opening.  I have reinstalled these versions, ensured I am up to date on the OS, and performed a clean installation on my NVIDIA card. (RTX 3080).  I also reset everything in AutoCADD to the default.  When I did the clan install, AutoCAD worked for one session, then gave up on me.  Another weird detail: AutoCAD Maps 2026 works!
I'm attaching this weird detail as well. The program freezes as the Autodesk Assistant dialogue tries to fade out; see the attached picture.  I do have another machine that I just put 2027 on, and it seems to operate normally.  It doesn't have the same NVIDIA card, but it does have the exact same driver.  Revit and other Autodesk products are working just fine.
Any thoughts on what else I should try?
Replies (37)
Message 21 of 38
austinmrTW5TT
Observer
Observer
Didn't have to delete it, just renamed it to something else, in my case I went with Renamedfile.dll
Message 22 of 38
tom2S3HC
Thank you for posting this comment.
Long story short, the Windows update uninstall was not an option and the DLL rename got us working, again (2025, 2024 did not launch still).  I think we would have spent quite a bit of time trying to deal with this, today if not for your comment here.
Message 23 of 38
fvossHMDGV
@austinmrTW5TT for the win!!  This was perfect.  I just changed the extension so it is now AdDownloaderCore.baddll.  Now I don't have to re-remove KB5083769 every week.
Message 24 of 38
GLDevco
I'll try this one - I've had my updates paused because of this issue.
Message 25 of 38
sdesjardinsEELUC
Observer
Observer
I got exactly the same here using AutoCAD 2025, English x64, than I have updated all the updates from Microsoft, from DELL and even updated the NVIDIA graphic pilot...  tried AutoCAD, 2024, 2025, 2026 and 2027... all the same result...
Really frustrating
Message 26 of 38
peter_plpm
Community Visitor
Community Visitor
Hi check out messages 16 and 23 this forum
This seems to be the goto workaround for now.
It has worked for me and I was then able to switch updates back on which has now downloaded KB5083769 and Acad is now running OK.
Thanks to austinmtTW5TT & fvssHMDGV
Message 27 of 38
prabhakar_sa
Thanks, this step worked for me and Civil 3D is running smoothly now.
Message 28 of 38
chad19
Community Visitor
Community Visitor
This worked for me - for now. Civil 3D 2025 would freeze after launch. I uninstalled the Windows update as described by others and things worked again for a few days. Then the freezing started again. I renamed the file as described by @austinmrTW5TT (I just added my initials after the file name). Boom, CAD is working again. Not even a reboot. Let's hope this sticks! Thank you.
Message 29 of 38
robbYYJ6L
Community Visitor
Community Visitor
Can confirm any name should work. I just renamed mine AdDownloaderCore2_ElectricBoogaloo.dll and I'm back up and running
Message 30 of 38
sdesjardinsEELUC
Observer
Observer
Thank you... It worked for me as well!!
Message 31 of 38
samsamdboy
Community Visitor
Community Visitor
I have the same issues and it says that i do not have the file mentioned earlier in the messages. I got no clue why nor how but if anyone as a solution I'm more than happy to try it.
Message 32 of 38
gtonks
Community Visitor
Community Visitor
Thank you, half a day wasted trying various workarounds and this one appears to be working
Message 33 of 38
jmonium
Had this problem occur this week too. Spent hours doing all the above, messing with office, access runtime (why is autocad dependent on office?), clean reinstalling, installing different versions.
What I had to do was run the program as an administrator. We'll see how long that works.
Message 34 of 38
carl
None of this worked for me. ACAD stopped loading after a windows security update  to the malware removal tool, KB2267602 Version 1.449.583.0
Message 35 of 38
carl
Further, another update was installed to the malware removal tool, KB890830. Neither of these updates can be found on the system in order to uninstall 😮
Tried via "uninstall Updates" in settings, as well as command prompt as administrator, NO success.
Message 36 of 38
jmonium
Try killing AceDriverTest.exe while it’s hanging. If it works, it may be an office conflict thing they’re working on.
Message 37 of 38
GLDevco
I have let the updates continue, and I appear to be unaffected after renaming the files per messages 16 and 23.  I noticed there have been a few updates on the licensing side from Autodesk over the past few weeks, which could be a part of it too, not sure.
Message 38 of 38
carl
It worked! Thank you! We wasted about four hours on this so far...😥
