AIDA Error - cx_freeze: Python in main script error
ftenhaus
ftenhaus
I have a Problem with the AIDA Software.
Everytime someone try to open it we get the Error "cx_freeze: Python in main script error"
It does not matter if we try it on Windows 8 or 10 or with firewall activated oder disabled.
We also tried to clean the temp folder, but even that did not work.
______________________________________________________
Ihr fandet einen Beitrag hilfreich? Dann vergebt dafür doch Kudos!
Eure Frage wurde erfolgreich gelöst? Dann einfach auf den 'Als Lösung akzeptieren'-Button klicken!
Franco Tenhaus
Otto
Hello ftenhaus
It appears that you are having trouble with your installation.
Changing the download method you are using has also helped others with this issue. Download and install per the Autodesk Virtual Agent in this case, rather than the install now option.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
Darin.Green
What seems to be the underlying issue or question you're trying to address? Do you need to know if your machines meet the necessary requirements for a particular Autodesk application?
If this information was helpful, please consider using the Accept Solution
ftenhaus
At one computer it worked with cleaning the temp folder (windows 10), but on windows 8 it did not work.
Thanks Otto, we will try to change the download method.
No Darin.Green, because someone installed Inventor many times, but everytime with failures.
Franco Tenhaus
Darin.Green
If you're using the Install Now Option, that's where most installations fail. Instead, download Inventor from the Autodesk Virtual Agent
  • Once there, use Download Links and navigate to the application you need to download.
NOTE: If there are multiple parts for the download, you'll need to click each part to download them, once they are downloaded double-click Part1 (which will automatically extract the remaining parts) to begin the installation.
