@Anonymous
The Autodesk Desktop Application is bloatware and should never be used or relied on..
Next just because there's an update there, doesn't mean it needs to be installed. Yes this is not something that Autodesk would say but from experience why break something that isn't broken (right @TravisNave). If the update fixes an issue that the users are experiencing, then apply it. If its a mid-year release or a benefit that's link to your subscription, install it if you want too.
In the end I always suggest that you should test these updates and make sure it works and meets your needs.. Too many times people upgrade just because its there and then regret it (and complain about it).. I always question why would you do this in a production type of environment. Why take the risk without testing.. Yeah sometimes you don't have the time to do this or there's no person who can perform the test, but in my opinion you should be taking the time to do this. You may end up wasting more time if you did update and it caused issues. Okay my 2 cents..
Not sure if that helps or not...
Mark Lancaster
& Autodesk Services MarketPlace Provider
