Hello @J-Bowers,
Yes, this is correct. Standard memory requirements of these processes are as small as cca 15-40MB each, but they may require more CPU power if they are blocked by an antivirus or a firewall. So if required, add them to the exceptions list (no-scan/no-block) in your antivirus.
You may have noticed multiple (typically up to 9) copies of the process AcWebBrowser.exe, resp. "Chromium host executable" running in your Windows Task Manager.
These are helper applications for Autodesk products, taking care of web communication - they are based on the web (HTML) component "Chromium" (the same root as Google Chrome). These processes are used e.g. for the online Help, licensing mechanism, the Start (Home) screen, for the update tool Desktop App, Infocenter, etc.
Take a look at the following Chromium host executable (AcWebBrowser.exe) shows high CPU usage
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
