3d max 2026 will not install
Dchimenti
Dchimenti
Hello.
I've just installed a fresh Windows 11 on to a new hard drive.
3D max will not install.
I'm getting the 1603 error
I did everything the provided solution link suggested I do to fix the problem. Nothing worked.
Everything else I've installed on this hard drive has worked perfectly. Including Adobe Suite.
Please advise.
Thanks.
-Derek
Dchimenti
Update:  I unchecked "civil view" from the install window and the install worked.
Naturally, I'd like to have the full package,
Simon_Weel
I had a look at 'path to files\3DSMAX_2026_en-US\x64\Comp\CV\pkg.CivilView.xml'. The installer should be located at x64/Comp/CV/3ds Max 2026 CivilView.msi (not in my case). An update should be in %PROGRAMDATA%\Autodesk\ApplicationPlugins\3dsmax-civilview-2026-1.2.6.0\ (not in my case). And then there's this line looking like a download link: NetSWDLD/ODIS/prd/2026/3DSMAX/9A828478-DA5C-4A6F-8C35-D9A0346A4538/pkg.civilview0.tar.xz.
That should be https://efulfillment.autodesk.com/NetSWDLD/ODIS/prd/2026/3DSMAX/9A828478-DA5C-4A6F-8C35-D9A0346A4538...
Maybe you can download and install it separately?
navya_gelli
Hello, @Dchimenti ,
Did the information provided by @Simon_Weel  help you and answer your question?
If yes, please click on the "Accept Solution" button on the post(s) that solved your problem. This will assist other community users in finding and benefiting from this information.
If not, please do not hesitate to give an update in this thread so all community members receive an update on the progression of your question, and can suggest next steps that may be helpful for you to achieve what you're looking for.
All the best,
Navya | Community Manager
