Bonjour à tous,
Je me permets de poster ici, car après 4 jours à tenter d´installer Autocad sans résultat je pense que j´ai besoin d´aide.
En effet jai la femeux problème avec l´erreur 1603.
Voici mon log :
2017/2/5:14:32:49 ux303 DESKTOP-TM3QIJ3 === Setup started on DESKTOP-TM3QIJ3 by ux303 === 2017/2/5:14:32:49 ux303 DESKTOP-TM3QIJ3 Path_Length: 154 2017/2/5:14:32:49 ux303 DESKTOP-TM3QIJ3 Current Directory C:\Users\ux303\Desktop\AutoCAD_2016_English_Win_64bit_dlm 2017/2/5:14:32:49 ux303 DESKTOP-TM3QIJ3 Launch 2017/2/5:14:32:49 ux303 DESKTOP-TM3QIJ3 CommandLine 2017/2/5:14:32:49 ux303 DESKTOP-TM3QIJ3 Path_Length: 154 2017/2/5:14:32:49 ux303 DESKTOP-TM3QIJ3 Current Directory C:\Users\ux303\AppData\Local\Temp\_AI96B5.tmp 2017/2/5:14:33:03 ux303 DESKTOP-TM3QIJ3 === Setup ended === 2017/2/5:14:32:50 ux303 DESKTOP-TM3QIJ3 === Setup started on DESKTOP-TM3QIJ3 by ux303 === 2017/2/5:14:32:50 ux303 DESKTOP-TM3QIJ3 Path_Length: 154 2017/2/5:14:32:50 ux303 DESKTOP-TM3QIJ3 Current Directory C:\Users\ux303\AppData\Local\Temp\_AI96B5.tmp 2017/2/5:14:32:50 ux303 DESKTOP-TM3QIJ3 Launch 2017/2/5:14:32:51 ux303 DESKTOP-TM3QIJ3 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\ux303\AppData\Local\Temp\_AI96B5.tmp\Setup\AcSetup.dll 2017/2/5:14:32:51 ux303 DESKTOP-TM3QIJ3 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink= 2017/2/5:14:32:56 ux303 DESKTOP-TM3QIJ3 PageOpen LaunchDialog 2017/2/5:14:33:07 ux303 DESKTOP-TM3QIJ3 PageOpen LicenseDialog 2017/2/5:14:33:11 ux303 DESKTOP-TM3QIJ3 PageOpen ProductInfoDialog 2017/2/5:14:33:25 ux303 DESKTOP-TM3QIJ3 PageOpen ProductSelectionDialog2 2017/2/5:14:33:30 ux303 DESKTOP-TM3QIJ3 PageOpen FullProgressDialog 2017/2/5:14:33:30 ux303 DESKTOP-TM3QIJ3 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Users\ux303\Desktop\AutoCAD_2016_English_Win_64bit_dlm\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q 2017/2/5:14:33:37 ux303 DESKTOP-TM3QIJ3 Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded 2017/2/5:14:33:37 ux303 DESKTOP-TM3QIJ3 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): "C:\Users\ux303\Desktop\AutoCAD_2016_English_Win_64bit_dlm\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe" /q 2017/2/5:14:33:43 ux303 DESKTOP-TM3QIJ3 Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Succeeded 2017/2/5:14:33:43 ux303 DESKTOP-TM3QIJ3 Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): "C:\Users\ux303\Desktop\AutoCAD_2016_English_Win_64bit_dlm\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe" /q /norestart /l C:\Users\ux303\AppData\Local\Temp\vcredist_x86_2010.log 2017/2/5:14:33:51 ux303 DESKTOP-TM3QIJ3 Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded 2017/2/5:14:33:51 ux303 DESKTOP-TM3QIJ3 Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): "C:\Users\ux303\Desktop\AutoCAD_2016_English_Win_64bit_dlm\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe" /q /norestart /l C:\Users\ux303\AppData\Local\Temp\vcredist_x64_2010.log 2017/2/5:14:34:01 ux303 DESKTOP-TM3QIJ3 Install Microsoft Visual C++ 2010 SP1 Redistributable (x64) Succeeded 2017/2/5:14:34:01 ux303 DESKTOP-TM3QIJ3 Installing Microsoft Visual C++ 2012 Redistributable (x86) Update 4: "C:\Users\ux303\Desktop\AutoCAD_2016_English_Win_64bit_dlm\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\ux303\AppData\Local\Temp\vcredist_x86_2012_UPD4.log 2017/2/5:14:34:04 ux303 DESKTOP-TM3QIJ3 Install Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Succeeded 2017/2/5:14:34:04 ux303 DESKTOP-TM3QIJ3 Installing Microsoft Visual C++ 2012 Redistributable (x64) Update 4: "C:\Users\ux303\Desktop\AutoCAD_2016_English_Win_64bit_dlm\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\ux303\AppData\Local\Temp\vcredist_x64_2012_UPD4.log 2017/2/5:14:34:07 ux303 DESKTOP-TM3QIJ3 Install Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Succeeded 2017/2/5:14:34:07 ux303 DESKTOP-TM3QIJ3 Installing DirectX Runtime: "C:\Users\ux303\Desktop\AutoCAD_2016_English_Win_64bit_dlm\3rdParty\DirectX\DXSETUP.exe" /silent 2017/2/5:14:34:18 ux303 DESKTOP-TM3QIJ3 Install DirectX Runtime Succeeded 2017/2/5:14:34:18 ux303 DESKTOP-TM3QIJ3 Installing Autodesk Material Library 2016: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2016" SETUP_PACKAGECODE={95CB8CCB-26D5-4C61-8F34-C6D922AB0D3C} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={F0736EFA-A11E-42C4-83B9-243BF2E8D69A} ADSK_SOURCE_ROOT="C:\Users\ux303\Desktop\AutoCAD_2016_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2017/2/5:14:35:19 ux303 DESKTOP-TM3QIJ3 Install Autodesk Material Library 2016 Failed Installation aborted, Result=1603 2017/2/5:14:35:19 ux303 DESKTOP-TM3QIJ3 Rollback DirectX Runtime Failed Failure is ignored, Result=1619 2017/2/5:14:35:19 ux303 DESKTOP-TM3QIJ3 Rollback Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Failed Failure is ignored, Result=1619 2017/2/5:14:35:20 ux303 DESKTOP-TM3QIJ3 Rollback Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Failed Failure is ignored, Result=1619 2017/2/5:14:35:20 ux303 DESKTOP-TM3QIJ3 Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x64) Failed Installation aborted, Result=1619 2017/2/5:14:35:20 ux303 DESKTOP-TM3QIJ3 Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted, Result=1619
J´ai tenté de suivre toutes les procédures sur les différents forum mais rien ne fonctionne : %TEMP%, desinstallation C++ ...
Je dois être mauvais ou faire les choses de la mauvaise facon, mais je vais devenir fou de ne pas réussir..
L´intallatioin d´un Cad2017 fonctionne mais j´ai également un problème de manager de licence..
En espérant trouver une solution grace à vous,
Merci d´avance,
Cordialement,
Merci de prendre contact avec votre communauté Autodesk.
Je vous prie dans un premier temps de désinstaller tous vos module VC++ et de vider votre répertoire %tmp%.
Téléchargez/installez votre application par le lien suivant:
- AutoCAD_2016_English_Win_64bit
Et si vous continuer à rencontrer une erreur, veuillez svp nous faire parvenir votre fichier setup.ini ainsi que les fichiers log ayant été généré sous %tmp%.
Cordialement
Bonjour,
Veuillez m´excuser mais je n´ai pas pu tenter l´installation avant.
Suite a un autre test, encore une fois je n´arrive pas à installer Autocad.
Voici ce que vous m´avez demander, j´espère qu´il y a une solution car jai un grand besoin d´autocad.
Je ne peux pas mettre tous ce qui est génerer car je suis limité a 3 PJ.
Sinon je pense que la solution finale et de revenir sur un win7 mais c´est un peu triste de faire cela.
Le fichier .ini :
[SETUP] PLATFORM=x64 SETUP_CODE={95CB8CCB-26D5-4C61-8F34-C6D922AB0D3C} TITLE=AcSetupRes.dll;1 LOG=%tmp%\Autodesk AutoCAD 2016 Setup.log EVALMSI=SetupRes\eval.msi PRIMARY_MSI=%platform%\%setupuilang%\acad\AcadPS\AcadPS.msi SYSUPDATE=MSI RESOURCE_PATH=%lang%\SetupRes INSTALL_PATH=%ProgramFiles%\Autodesk CREATE_DESKTOP_SHORTCUT=YES LPMODE=NO_ADD_LP DEFAULTMEDIALANGUAGE=en-US #============================= Help Link ============================= DOCUMENT_LINK=http://www.autodesk.com/installation-help-2016-%setupuilang% DOCUMENT_FALLBACK_LINK=Docs\acad_install_help\index.html SYSTEMREQUIRE_LINK=http://www.autodesk.com/autocad-win-sys-reqs-2016-%setupuilang% SYSTEMREQUIRE_FALLBACK_LINK=Docs\acad_sysreq\index.html SUPPORT_LINK=http://www.autodesk.com/autocad-win-readme-2016-%setupuilang% SUPPORT_FALLBACK_LINK=Readme\readme.html #============================= Platform Requirement ============================= OSMAJVER=5 OSMINVER=1 SPMAJVER=2 #============================= UI ============================= TOP_BANNER=SetupRes\TopBanner.png LOADING_IMAGE=SetupRes\AutoCAD.png BACKGROUND_IMAGE=SetupRes\AutoCAD.png LOGO=SetupRes\Adsk_white.png UI_MODE= #============================= Deployment Info ============================= DEPLOYMENT_NAME= CLIENT_LOGGING=YES EXTRA_FILES=acad;*.exe:Setup:CER:eula:3rdParty\msi:nlsdl:3rdParty\NET:setupres:%lang% PRODLINE=ACD #============================= Install Execute & UI Sequence ============================= EXE_SEQUENCE=ACAD_MAIN;ACAD;ACAD_LP;ACAOE;ACADPV;NLM;CADM;SNAP;AUTODESK_RECAP;ACADAPPMGR;ACADFEATUREDAPPS;PERFORMANCETOOL;GLUE_PLUGIN_AUT;A360Desktop;ADAPPLICATIONMANAGER INSTALL_SEQUENCE=NLM;CADM;SNAP;ACAD_MAIN;ACAD;ACAD_LP;ACAOE;ACADPV;AUTODESK_RECAP;ACADAPPMGR;ACADFEATUREDAPPS;PERFORMANCETOOL;GLUE_PLUGIN_AUT;A360Desktop;ADAPPLICATIONMANAGER UI_SEQUENCE=LaunchDlg;BeginDeploymentDlg;LicenseDlg;ProductInfoDlg;ProductSelectionDlg2;ACAD_MAIN;ACAD;ACAD_LP;ACAOE;ACADPV;CADM;SNAP;A360Desktop;ADAPPLICATIONMANAGER;FullProgressDlg;InstallCompleteDlg;DeploymentCompleteDlg;DeploymentFailedDlg #============================= AdLM ProdKey Info ============================= ADLM_CONFIG_FILE=Setup\AutoCADConfig.pit ADLM_PIT_DLL=Setup\adlmPIT.dll ADLM_VERSION=2016.0.0.F ADLM_TRIAL_DAYS=30 #============================= Custom Callback Function ============================= CB_FUNC=CustomPlatformCheck CB_SOURCE=Setup\AcSetup.dll CB_PARAM=5.2-x64;5.1-x86;http://www.autodesk.com/autocad-win-sys-reqs-2016- CB_DESCRIPTION=Custom callback function to check platform support. #============================= Global MSI Properties ============================= UPI2={F0736EFA-A11E-42C4-83B9-243BF2E8D69A} BUILDNUM=20.1.49.0 UNITTYPE=PRD - Product PATH_LENGTH=154 [GLOBAL_MSI_PROPERTIES] #============================= ACAD ============================= [ACAD] PLATFORM=NATIVE PRODUCT_NAME=AutoCAD 2016 Core SHAREDPROPERTIES_REQUIRED=INSTALLDIR;ACADSERIALPREFIX;ACADSERIALNUMBER;ACADSTANDALONENETWORKTYPE;ADSK_LAUNCH_MODE;LOCKSECURITYSETTINGS;LEGACYCODESEARCH; EXE_PATH=%platform%\acad\acad.msi EXE_PARAM= EXTRA_FILES=acad;acad\*.ico LOG=%tmp%\Autodesk AutoCAD 2016 Core Install.log ROLLBACKABLE=YES HIDDEN=YES ADMIN_INSTALL=YES DEPLOYMENTLANGUAGE= ACTION=INSTALL REMOVE_PATH= USE_EXTERNAL_UI=YES UI_SEQUENCE=PathCustomizationPage_ACAD CanSpan=1 AVAILABLELANGUAGES=en-US UPI2_x64={550B3898-CAAD-4AC6-97F0-4FA0C87AC877} DISK_LABEL=acad2016 DISK_PROMPT=AcSetupRes.dll;11 [ACAD_en-US] DISK_LABEL=acad2016 DISK_PROMPT=AcSetupRes.dll;11 #============================= ACAD Language Pack ============================= [ACAD_LP] PLATFORM=NATIVE PRODUCT_NAME=AutoCAD 2016 Language Core EXE_PATH=%platform%\%lang%\acad\AcadLP\AcadLP.msi EXE64_PATH=%platform%\%lang%\acad\AcadLP\AcadLP.msi LOG=%tmp%\Autodesk AutoCAD 2016 LangPack Install.log HIDDEN=YES ADMIN_INSTALL=YES ACTION=INSTALL DISK_PROMPT=AcSetupRes.dll;11 DISK_LABEL=acad2016 UI_SEQUENCE=PathCustomizationPage_ACAD LPMODE=MLD_ADR DEFAULTMEDIALANGUAGE=en-US AVAILABLELANGUAGES=en-US #============================= ACAD Product Specific Pack ============================= [ACAD_MAIN] PLATFORM=NATIVE PRODUCT_NAME=Autodesk® AutoCAD® 2016 SHAREDPROPERTIES_AVAILABLE=INSTALLDIR;ACADSERIALPREFIX;ACADSERIALNUMBER;ACADSTANDALONENETWORKTYPE;ADSK_LAUNCH_MODE;NIWSELECTION;ACADSERVERPATH;ACADSERVERFMTPATH;ACADLICENSETYPE;ACADLICENSESERVERTYPE;ACAD_LICENSESERVER_DISTRIBUTED;ADLM_PRODKEY;ACADProfile_TrustedPaths;ACADProfile_TrustedDomains;ACAD_USE_ONLINE_CONTENT;LOCKSECURITYSETTINGS;LEGACYCODESEARCH;ACADDisplayStartTab;SECURELOAD PREREQUISITE=ACAD_VISTA_BLOCK;IE;SSE2;DOTNET45;DOTNET45LANG;VCREDIST2008SP1X86;VCREDIST2008SP1X64;VCREDIST2010SP1X86;VCREDIST2010SP1X64;VCREDIST2012X86UPD4;VCREDIST2012X64UPD4;DIRECTX;MSXML6;WMF95X64;CM;CMILB;CMAIL;SNAP_PRE POSTREQUISITE=ACADSKETCHUPIMPORT SHAREDREQUISITE=ACAD;ACAD_LP;ACAOE;ACADPV EXE_PATH=%platform%\%lang%\acad\AcadPS\AcadPS.msi LOG=%tmp%\Autodesk AutoCAD 2016 PSPack Install.log ADMIN_INSTALL=YES PRODUCT_MESSAGE=AcSetupRes.dll;41 PRODUCT_INSTALLED_INFO_MSG=AcSetupRes.dll;70 PRODUCT_INSTALLED_INFO_URL=AcSetupRes.dll;71 EULA_PATH=eula ACTION=INSTALL DISK_PROMPT=AcSetupRes.dll;11 DISK_LABEL=acad2016 EXTRA_FEATURES=Express_Tools README_FILE=help\contexthelp\readme.htm;AcSetupRes.dll;4 LAUNCH_EXE=acad.exe UI_SEQUENCE=InstallTypePage;ContentLocationPage;ExecutableFileSettingsPage;PathCustomizationPage_ACAD;AddAdditionalFilesPage;WorkstationSettingPage;StartTabSettingsPage;ServicePackPageForDeploy;ServicePackPageForInstall;InfoCenterCommCenterPage;OnlineResourcesPage MAINTENANCE_UI_SEQUENCE=OemPreinstallLicenseDlg;OemPreinstallProductInfoDlg;MaintenanceDlg;AddRemoveFeaturesDlg;RepairDlg;MaintVerifyReadyDlg;FullProgressDlg;MaintCompleteDlg;MaintFailedDlg VC_FUNC=CheckInstallCondition VC_SOURCE=Setup\AcSetup.dll VC_PARAM=2;4;30;http://www.autodesk.com/certified-hardware VC_DESCRIPTION=Check Hardware Requirements SUMMARY_FUNC=LoadSummary_ACAD SUMMARY_SOURCE=SetupAcadUi.dll SUBCOMPONENT=ACADAPPMGR;ACADFEATUREDAPPS;PERFORMANCETOOL;GLUE_PLUGIN_AUT LPMODE=MLD_ADR DEFAULTMEDIALANGUAGE=en-US AVAILABLELANGUAGES=en-US #============================= AUTODESK_RECAP ============================= [AUTODESK_RECAP] PLATFORM=x64 PRODUCT_NAME=Autodesk® ReCap™ PREREQUISITE=VCREDIST2008SP1X86_6161;VCREDIST2008SP1X64_6161;VCREDIST2010SP1X86;VCREDIST2010SP1X64;VCREDIST2012X86UPD4;VCREDIST2012X64UPD4;DOTNET4;FAROSDK EXE_PATH=%platform%\RC2016\AutodeskReCap.msi EXE_PARAM= EXTRA_FILES=RC2016;%platform%\RC2016\*.PIT LOG=%tmp%\Autodesk ReCap Install.log ROLLBACKABLE=NO ADMIN_INSTALL=YES PRODUCT_MESSAGE=AutodeskReCapSetupRes.dll;116 EULA_PATH=eula ACTION=INSTALL DISK_PROMPT= DISK_LABEL= REMOVE_PATH= USE_EXTERNAL_UI=YES PRODUCT_ICON=SetupRes\AutodeskReCap.ico REMOVE_PREV_VERSION=YES UI_SEQUENCE=InstallTypePage;PathCustomizationPage;AddAdditionalFilesPage;WorkstationSettingPage;ServicePackPageForDeploy;ServicePackPageForInstall MAINTENANCE_UI_SEQUENCE=MaintenanceDlg;RepairDlg;MaintVerifyReadyDlg;FullProgressDlg;MaintCompleteDlg;MaintFailedDlg LPMODE=MLD_ADR DEFAULTMEDIALANGUAGE=en-US AVAILABLELANGUAGES=en-US [AUTODESK_RECAP_en-US] DISK_LABEL= DISK_PROMPT= #============================= ACA OE ============================= [ACAOE] PLATFORM=NATIVE PRODUCT_NAME=ACA & MEP 2016 Object Enabler SHAREDPROPERTIES_REQUIRED=INSTALLDIR EXE_PATH=%platform%\ACAOE\AcaOE.msi LOG=%tmp%\Autodesk AutoCAD 2016 OEPack Install.log HIDDEN=YES ADMIN_INSTALL=YES ACTION=INSTALL DISK_PROMPT=AcSetupRes.dll;11 DISK_LABEL=acad2016 UI_SEQUENCE=PathCustomizationPage_ACAD AVAILABLELANGUAGES=en-US UPI2_x64={6592D152-2411-4A82-AEE2-A11F0DF77756} [ACAOE_en-US] DISK_LABEL=acad2016 DISK_PROMPT=AcSetupRes.dll;11 #============================= ACAD Private ============================= [ACADPV] PLATFORM=NATIVE PRODUCT_NAME=AutoCAD 2016 SHAREDPROPERTIES_REQUIRED=INSTALLDIR;ACADSERIALPREFIX;ACADSERIALNUMBER;ACADSTANDALONENETWORKTYPE;ADSK_LAUNCH_MODE;NIWSELECTION;ACADSERVERPATH;ACADSERVERFMTPATH;ACADLICENSETYPE;ACADLICENSESERVERTYPE;ACAD_LICENSESERVER_DISTRIBUTED;ADLM_PRODKEY;ACADProfile_TrustedPaths;ACADProfile_TrustedDomains;ACAD_USE_ONLINE_CONTENT;ACADDisplayStartTab;LOCKSECURITYSETTINGS;SECURELOAD EXE_PATH=%platform%\ACADPRIVATE\AcadPrivate.msi LOG=%tmp%\Autodesk AutoCAD 2016 PrivatePack Install.log HIDDEN=YES ADMIN_INSTALL=YES ACTION=INSTALL DISK_PROMPT=AcSetupRes.dll;11 DISK_LABEL=acad2016 UI_SEQUENCE=PathCustomizationPage_ACAD #============================= Block Vista version Check ============================= UPI2_x64={F09525A1-9552-4606-968D-C616A2858E0F} [ACAD_VISTA_BLOCK] PRODUCT_NAME=Block Vista version Check EXE_PATH=NULL VC_FUNC=CheckForOSBlock VC_SOURCE=Setup\AcSetup.dll VC_PARAM=6.0-x64;6.0-x86;http://www.autodesk.com/autocad-win-sys-reqs-2016-%setupuilang% VC_DESCRIPTION=Block Vista version Check #============================= Common Autodesk Components ============================= #============================= Autodesk Tools ============================= [NLM] PLATFORM=NATIVE PRODUCT_NAME=Network License Manager EXE_PATH=%platform%\%lang%\Tools\NLM\NLM.msi EXE_PARAM=ALLUSERS=1 LOG=%tmp%\NLM Install.log PRODUCT_MESSAGE=AcSetupRes.dll;47 IGNORE_FAILURE=YES ALLOW_ADD_REMOVE=NO ACTION=INSTALL DISKCOST=8000000 INSTALL_TYPE=4 LPMODE=MLD_ADR DEFAULTMEDIALANGUAGE=en-US AVAILABLELANGUAGES=en-US [CADM] PLATFORM=NATIVE PRODUCT_NAME=Autodesk CAD Manager Tools PREREQUISITE=SSE2;VCREDIST2012X86UPD4;VCREDIST2012X64UPD4 EXE_PATH=%platform%\%lang%\Tools\CADManager\CADManager.msi LOG=%tmp%\CADManager Install.log PRODUCT_MESSAGE=AcSetupRes.dll;46 IGNORE_FAILURE=YES ALLOW_ADD_REMOVE=NO ACTION=INSTALL INSTALL_TYPE=4 LPMODE=MLD_ADR DEFAULTMEDIALANGUAGE=en-US AVAILABLELANGUAGES=en-US #============================= Content Service ============================= [SNAP] PRODUCT_NAME=Autodesk Content Service PREREQUISITE=DOTNET45;VCREDIST2008SP1X86;VCREDIST2010SP1X86;VCREDIST2012X86UPD4 EXE_PATH=%platform%\Tools\snap\ContentService.msi EXE_PARAM=INSTALLMODE=PUBLIC AUTOSTART=1 LOG=%tmp%\Autodesk Content Service.log PRODUCT_MESSAGE=ContentServiceRes.dll;417 IGNORE_FAILURE=YES DISK_PROMPT=AcSetupRes.dll;11 DISK_LABEL=acad2016 DISKCOST=37000000 INSTALL_TYPE=4 UI_SEQUENCE=Snap_InstallModePage VC_FUNC=ACSCheck_StandAlone VC_SOURCE=Setup\ContentServiceUI.dll LPMODE=MLD_INV DEFAULTMEDIALANGUAGE=en-US AVAILABLELANGUAGES=en-US [SNAP_en-US] DISK_LABEL=acad2016 DISK_PROMPT=AcSetupRes.dll;11 #============================= ContentService Language Pack Postrequisite ============================= [SNAP_LANGPACK] PRODUCT_NAME=Autodesk Content Service Language Pack EXE_PATH=%platform%\%lang%\Tools\snap\ContentServiceLP.msi [SNAP_PRE] PRODUCT_NAME=Autodesk Content Service PREREQUISITE=DOTNET45;VCREDIST2008SP1X86;VCREDIST2010SP1X86 EXE_PATH=%platform%\Tools\snap\ContentService.msi EXE_PARAM=INSTALLMODE=PRIVATE AUTOSTART=0 LOG=%tmp%\Autodesk Content Service.log IGNORE_FAILURE=YES ACTION=INSTALL DISK_PROMPT=AcSetupRes.dll;11 DISK_LABEL=acad2016 DISKCOST=37000000 VC_FUNC=ACSCheck_Inline VC_SOURCE=Setup\ContentServiceUI.dll LPMODE=MLD_INV DEFAULTMEDIALANGUAGE=en-US AVAILABLELANGUAGES=en-US [SNAP_PRE_en-US] DISK_LABEL=acad2016 DISK_PROMPT=AcSetupRes.dll;11 #============================= ContentService Language Pack Postrequisite ============================= [SNAP_PRE_LANGPACK] PRODUCT_NAME=Autodesk Content Service Language Pack EXE_PATH=%platform%\%lang%\Tools\snap\ContentServiceLP.msi #============================= Common Autodesk Content ============================= [CM] PLATFORM=ALL PRODUCT_NAME=Autodesk Material Library 2016 EXE_PATH=Content\ADSKMaterials\2016\CM\MaterialLibrary2016.msi EXTRA_FILES=acad;Content\ADSKMaterials\2016\CM\*.cab LOG=%tmp%\MaterialLibrary2016CM.log ADMIN_INSTALL=NO ACTION=INSTALL DISKCOST=88000000 [CMILB] PLATFORM=ALL PRODUCT_NAME=Autodesk Material Library 2016 - Base Image Library EXE_PATH=Content\ADSKMaterials\2016\ILB\BaseImageLibrary2016.msi EXTRA_FILES=acad;Content\ADSKMaterials\2016\ILB\*.cab LOG=%tmp%\MaterialLibrary2016CMILB.log ADMIN_INSTALL=NO ACTION=INSTALL DISKCOST=81000000 [CMAIL] PLATFORM=ALL PRODUCT_NAME=Autodesk® Material Library 2016 - Advanced Image Library PREREQUISITE=CM EXE_PATH=Content\ADSKMaterials\2016\AIL\AdvancedImageLibrary2016.msi EXTRA_FILES=acad;Content\ADSKMaterials\2016\AIL\*.cab LOG=%tmp%\AdvancedImageLibrary2016.log ADMIN_INSTALL=NO ALLOW_ADD_REMOVE=NO ACTION=INSTALL DISKCOST=762000000 #============================= A360 Desktop ============================= [A360Desktop] PLATFORM=NATIVE PRODUCT_NAME=A360 Desktop EXE_PATH=%platform%\Components\Cloudsync\AdSync.msi EXE_PARAM=ADLANGUAGE=%selectedlang% ENABLESYNC=#1 LOG=%tmp%\CloudsyncInstall.log ROLLBACKABLE=NO ADMIN_INSTALL=YES PRODUCT_MESSAGE=A360SetupUiRes.dll;300 IGNORE_FAILURE=YES SHARED_COMPONENT=YES ACTION=INSTALL UI_SEQUENCE=A360CustomConfigPage #============================= Autodesk App Manager AppStore bundle for AutoCAD ============================= [ACADAPPMGR] PLATFORM=NATIVE PRODUCT_NAME=Exchange App Manager EXE_PATH=%platform%\ACADExtApps\AutodeskAppManager.msi EXE_PARAM=ADLANGUAGE=%selectedlang% LOG=%tmp%\ACADExtApps_AppManager_Install.log ADMIN_INSTALL=YES PRODUCT_MESSAGE=AcSetupRes.dll;80 IGNORE_FAILURE=YES ACTION=INSTALL #============================= Autodesk SketchUp Import AppStore bundle for AutoCAD ============================= [ACADSKETCHUPIMPORT] PLATFORM=NATIVE PRODUCT_NAME=SketchUp Import plug-in EXE_PATH=%platform%\ACADExtApps\AutodeskImportSkp.msi EXE_PARAM=ADLANGUAGE=%selectedlang% LOG=%tmp%\ACADExtApps_SketchUpImport_Install.log ADMIN_INSTALL=YES PRODUCT_MESSAGE=AcSetupRes.dll;82 IGNORE_FAILURE=YES ACTION=INSTALL #============================= Autodesk Featured Apps AppStore bundle for AutoCAD ============================= [ACADFEATUREDAPPS] PLATFORM=NATIVE PRODUCT_NAME=Exchange Featured Apps plug-in EXE_PATH=%platform%\ACADExtApps\AutodeskFeaturedApps.msi EXE_PARAM=ADLANGUAGE=%selectedlang% LOG=%tmp%\ACADExtApps_FeaturedApps_Install.log ADMIN_INSTALL=YES PRODUCT_MESSAGE=AcSetupRes.dll;81 IGNORE_FAILURE=YES ACTION=INSTALL #============================= Performance Tool ============================= [PERFORMANCETOOL] PLATFORM=NATIVE PRODUCT_NAME=Autodesk® AutoCAD® Performance Reporting Tool EXE_PATH=Tools\PerformanceTool\AcPerfMon.msi EXE_PARAM= LOG=%tmp%\Performance_Tool_Install.log ADMIN_INSTALL=YES PRODUCT_MESSAGE=AcSetupRes.dll;83 IGNORE_FAILURE=YES ACTION=INSTALL #============================= Autodesk BIM 360 Add-in for AutoCAD 2016 ============================= [GLUE_PLUGIN_AUT] PLATFORM=NATIVE PRODUCT_NAME=Autodesk® BIM 360™ Add-in for AutoCAD® 2016 EXE_PATH=%platform%\Components\BIM360\setup.msi LOG=%tmp%\Autodesk BIM 360 Add-in for AutoCAD 2016 Install.log PRODUCT_MESSAGE=AcSetupRes.dll;84 IGNORE_FAILURE=YES ACTION=INSTALL #============================= Autodesk Application Manager ============================= [ADAPPLICATIONMANAGER] PLATFORM=NATIVE PRODUCT_NAME=Autodesk Application Manager EXE_PATH=x86\ADAPPLICATIONMANAGER\AdApplicationManager-WebInstaller.exe EXE_PARAM= IGNORE_FAILURE=YES ACTION=INSTALL DISKCOST=80000000 UI_SEQUENCE=AdAppManPage VC_FUNC=AdAppManCheck VC_SOURCE=Setup\SetupUi.dll VC_PARAM=4.0.69.0 HIDDEN_COMPONENT=YES #============================= 3rd Party Components ============================= #============================= FAROSDK ============================= [FAROSDK] PLATFORM=NATIVE PRODUCT_NAME=FARO LS 5.2.0.35213 EXE_PATH=3rdParty\%platform%\FaroSDK\FARO.LS_5.2.0.35213.msi LOG=%tmp%\FAROSDK.log IGNORE_FAILURE=YES [IE] PRODUCT_NAME=Internet Explorer EXE_PATH=NULL PRODUCT_MESSAGE=SetupRes.dll;209 ACTION=INSTALL VC_FUNC=IeVerCheck VC_SOURCE=Setup\SetupUi.dll VC_PARAM=7.0.5730;7.0;1 VC_DESCRIPTION=Detecting Internet Explorer [MSI] PLATFORM=ALL PRODUCT_NAME=Windows Installer Redistributable EXE_PATH=3rdParty\msi EXE_PARAM=/quiet /norestart VC_FUNC=MsiVerCheck VC_SOURCE=Setup\SetupUi.dll VC_PARAM=4.0 VC_DESCRIPTION=Detecting MSI [NLSDL] PLATFORM=NATIVE PRODUCT_NAME=Microsoft NLS Downlevel APIs EXE_PATH=NLSDL\nlsdl.x86.exe EXE64_PATH=NLSDL\nlsdl.amd64.exe EXE_PARAM=/quiet /norestart IGNORE_FAILURE=YES [MSXML6] PLATFORM=NATIVE PRODUCT_NAME=MSXML 6 EXE_PATH=3rdParty\x86\msxml6\msxml6.msi EXE64_PATH=3rdParty\x64\msxml6\msxml6_x64.msi IGNORE_FAILURE=YES VC_FUNC=MsxmlVerCheck VC_SOURCE=Setup\SetupUi.dll VC_PARAM=6.0 #============================= VCREDIST Begin ============================= [VCREDIST2012X86UPD4] PLATFORM=ALL PRODUCT_NAME=Microsoft Visual C++ 2012 Redistributable (x86) Update 4 EXE_PATH=3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe EXE_PARAM=/install /quiet /norestart /log %temp%\vcredist_x86_2012_UPD4.log IGNORE_FAILURE=YES IGNORE_ERROR=5100 VC_FUNC=VC2012Redistx86check VC_SOURCE=Setup\SetupUi.dll VC_PARAM=11.0.61030 [VCREDIST2012X64UPD4] PLATFORM=x64 PRODUCT_NAME=Microsoft Visual C++ 2012 Redistributable (x64) Update 4 EXE64_PATH=3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe EXE_PARAM=/install /quiet /norestart /log %temp%\vcredist_x64_2012_UPD4.log IGNORE_FAILURE=YES IGNORE_ERROR=5100 VC_FUNC=VC2012Redistx64check VC_SOURCE=Setup\SetupUi.dll VC_PARAM=11.0.61030 #============================= VCREDIST Begin ============================= [VCREDIST2010SP1X86] PLATFORM=ALL PRODUCT_NAME=Microsoft Visual C++ 2010 SP1 Redistributable (x86) EXE_PATH=3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe EXE_PARAM=/q /norestart /l %temp%\vcredist_x86_2010.log IGNORE_ERROR=5100 VC_FUNC=VCx86RedisCheck VC_SOURCE=Setup\SetupUi.dll VC_PARAM={F0C3E5D1-1ADE-321E-8167-68EF0DE699A5} [VCREDIST2010SP1X64] PLATFORM=x64 PRODUCT_NAME=Microsoft Visual C++ 2010 SP1 Redistributable (x64) EXE64_PATH=3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe EXE_PARAM=/q /norestart /l %temp%\vcredist_x64_2010.log IGNORE_ERROR=5100 VC_FUNC=VCx64RedisCheck VC_SOURCE=Setup\SetupUi.dll VC_PARAM={1D8E6291-B0D5-35EC-8441-6616F567A0F7} [VCREDIST2008SP1X86] PLATFORM=ALL PRODUCT_NAME=Microsoft Visual C++ 2008 SP1 Redistributable (x86) EXE_PATH=3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe EXE_PARAM=/q ROLLBACKABLE=NO IGNORE_ERROR=YES VC_FUNC=VCx86RedisCheck VC_SOURCE=Setup\SetupUi.dll VC_PARAM={1F1C2DFC-2D24-3E06-BCB8-725134ADF989} [VCREDIST2008SP1X64] PLATFORM=x64 PRODUCT_NAME=Microsoft Visual C++ 2008 SP1 Redistributable (x64) EXE64_PATH=3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe EXE_PARAM=/q ROLLBACKABLE=NO IGNORE_ERROR=YES VC_FUNC=VCx64RedisCheck VC_SOURCE=Setup\SetupUi.dll VC_PARAM={4B6C7001-C7D6-3710-913E-5BC23FCE91E6} [VCREDIST2008SP1X64_6161] PLATFORM=x64 PRODUCT_NAME=Microsoft Visual C++ 2008 SP1 Redistributable (x64) 9.0.30729.6161 EXE64_PATH=3rdParty\x64\VCRedist\2008SP1.6161\vcredist_x64.exe EXE_PARAM=/q ROLLBACKABLE=NO IGNORE_ERROR=YES VC_FUNC=VCx64RedisCheck VC_SOURCE=Setup\SetupUi.dll VC_PARAM={5FCE6D76-F5DC-37AB-B2B8-22AB8CEDB1D4} [VCREDIST2008SP1X86_6161] PLATFORM=ALL PRODUCT_NAME=Microsoft Visual C++ 2008 SP1 Redistributable (x86) 9.0.30729.6161 EXE_PATH=3rdParty\x86\VCRedist\2008SP1.6161\vcredist_x86.exe EXE_PARAM=/q ROLLBACKABLE=NO IGNORE_ERROR=YES VC_FUNC=VCx86RedisCheck VC_SOURCE=Setup\SetupUi.dll VC_PARAM={9BE518E6-ECC6-35A9-88E4-87755C07200F} #============================= VCREDIST End ============================= [SSE2] PRODUCT_NAME=SSE2 Support Check EXE_PATH=NULL PRODUCT_MESSAGE=SSE2 Support Check VC_FUNC=CheckForSSE2Support VC_SOURCE=Setup\AcSetup.dll VC_DESCRIPTION=SSE2 Support Check [DOTNET4] PLATFORM=ALL PRODUCT_NAME=.NET Framework Runtime 4.0 EXE_PATH=3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe EXE_PARAM=/q DISKCOST=352037424 VC_FUNC=DotnetVerify VC_SOURCE=Setup\SetupUi.dll VC_PARAM=.NET Framework 4 Full VC_DESCRIPTION=Detecting .NET 4.0 Runtime [DOTNET45] PLATFORM=ALL PRODUCT_NAME=.NET Framework Runtime 4.5 EXE_PATH=3rdParty\NET\45\wcu\dotNetFramework\dotNetFx45_Full_x86_x64.exe EXE_PARAM=/q /norestart IGNORE_FAILURE=YES DISKCOST=388037424 VC_FUNC=DotnetVerify VC_SOURCE=Setup\SetupUi.dll VC_PARAM=.NET Framework 4.5 Full VC_DESCRIPTION=Detecting .NET 4.5 Runtime [DOTNET45LANG] PRODUCT_NAME=.NET Framework Runtime 4.5 Language Pack EXE_PATH=3rdParty\NET\45\wcu\dotNetFramework\dotNetFx45LP_Full_x86_x64_%lcid%.exe EXE_PARAM=/q /norestart EXE_LANGS=1025;1028;1029;1030;1031;1032;1034;1035;1036;1037;1038;1040;1041;1042;1044;1045;1046;1049;1053;1055;2052;2070;3082 IGNORE_FAILURE=YES DISKCOST=3000000 VC_FUNC=DotnetLangPacksVerCheck VC_SOURCE=Setup\SetupUi.dll VC_PARAM=%lcid%;4.5.50709 VC_DESCRIPTION=Detecting .NET 4.5 Runtime IGNORE_LANGS=1033 LPMODE=MLD_ADR #============================= DOTNET Ends ============================= [DIRECTX] PLATFORM=ALL PRODUCT_NAME=DirectX Runtime EXE_PATH=3rdParty\DirectX\DXSETUP.exe EXE_PARAM=/silent IGNORE_FAILURE=YES DISKCOST=50000000 [WMF95X64] PLATFORM=x64 PRODUCT_NAME=Microsoft Windows Media Format 9.5 Series Runtime EXE64_PATH=3rdParty\x64\wmf\95\wmfdist64.exe EXE_PARAM=/quiet ROLLBACKABLE=NO IGNORE_FAILURE=YES ACTION=INSTALL VC_FUNC=WMFCheck VC_SOURCE=Setup\SetupUi.dll VC_PARAM=9.5 #============================= Common Main Pages: Install Mode ============================= [LaunchDlg] UI_CREATOR=LaunchDialog UI_SOURCE=Setup\SetupAcadUi.dll BACKGROUND_IMAGE=SetupRes\AutoCAD.png [LicenseDlg] UI_CREATOR=LicenseDialog UI_SOURCE=Setup\SetupAcadUi.dll UI_CONDITION=NOT ADSK_OEMPREINSTALL [ProductSelectionDlg2] UI_CREATOR=ProductSelectionDialog2 UI_SOURCE=Setup\SetupAcadUi.dll BACKGROUND_IMAGE=SetupRes\AutoCAD.png UI_POSTCONSTRUCT=SetInstallPathEditorStatus UI_POSTCONSTRUCT_SOURCE=Setup\AcSetup.dll [ProductInfoDlg] UI_CREATOR=ProductInfoDialog UI_SOURCE=Setup\SetupAcadUi.dll UI_CONDITION=ADSK_LAUNCH_MODE<>"TOOLS" [FullProgressDlg] UI_CREATOR=FullProgressDialog UI_SOURCE=Setup\SetupAcadUi.dll UI_INFOTAINMENT_PATH=SetupRes\Infotainment\Images UI_INFOTAINMENT_ELAPSE=18000 BACKGROUND_IMAGE=SetupRes\AutoCAD.png [InstallCompleteDlg] UI_CREATOR=InstallCompleteDialog UI_SOURCE=Setup\SetupAcadUi.dll UI_CONDITION=ADSK_LAUNCH_MODE<>"DEPLOYMENT" AND ADSK_LAUNCH_MODE<>"MINIMAL_DEPLOYMENT" BACKGROUND_IMAGE=SetupRes\AutoCAD.png #============================= Common Main Pages: Deploy Mode ============================= [BeginDeploymentDlg] UI_CREATOR=BeginDeploymentDialog UI_SOURCE=Setup\DeployUi.dll UI_CONDITION=ADSK_LAUNCH_MODE="DEPLOYMENT" OR ADSK_LAUNCH_MODE="MINIMAL_DEPLOYMENT" #============================= Common Main Pages: Deploy Mode ============================= [DeploymentCompleteDlg] UI_CREATOR=DeploymentCompleteDialog UI_SOURCE=Setup\DeployUi.dll UI_CONDITION=(ADSK_LAUNCH_MODE="DEPLOYMENT" OR ADSK_LAUNCH_MODE="MINIMAL_DEPLOYMENT") AND ADSK_SETUP_SUCCEEDED BACKGROUND_IMAGE=SetupRes\AutoCAD.png [DeploymentFailedDlg] UI_CREATOR=DeploymentFailedDialog UI_SOURCE=Setup\DeployUi.dll UI_CONDITION=(ADSK_LAUNCH_MODE="DEPLOYMENT" OR ADSK_LAUNCH_MODE="MINIMAL_DEPLOYMENT") AND NOT ADSK_SETUP_SUCCEEDED BACKGROUND_IMAGE=SetupRes\AutoCAD.png #============================= Common Config pages: Install Mode ============================= [InstallTypePage] UI_CREATOR=InstallTypePage UI_SOURCE=Setup\SetupAcadUi.dll [Snap_InstallModePage] UI_CREATOR=InstallModePage UI_SOURCE=Setup\ContentServiceUI.dll #============================= Common Config Pages: Deploy Mode ============================= [ContentLocationPage] UI_CREATOR=ContentLocationPage UI_SOURCE=Setup\SetupAcadUi.dll UI_CONDITION=ADSK_LAUNCH_MODE="DEPLOYMENT" OR ADSK_LAUNCH_MODE="MINIMAL_DEPLOYMENT" [PathCustomizationPage] UI_CREATOR=PathCustomizationPage UI_SOURCE=Setup\DeployUi.dll UI_CONDITION=ADSK_LAUNCH_MODE="DEPLOYMENT" OR ADSK_LAUNCH_MODE="MINIMAL_DEPLOYMENT" [ExecutableFileSettingsPage] UI_CREATOR=ExecutableFileSettingsPage UI_SOURCE=Setup\AcDeployUi.dll UI_CONDITION=ADSK_LAUNCH_MODE="DEPLOYMENT" OR ADSK_LAUNCH_MODE="MINIMAL_DEPLOYMENT" [PathCustomizationPage_ACAD] UI_CREATOR=PathCustomizationPage_ACAD UI_SOURCE=Setup\AcDeployUi.dll UI_CONDITION=ADSK_LAUNCH_MODE="DEPLOYMENT" OR ADSK_LAUNCH_MODE="MINIMAL_DEPLOYMENT" [AddAdditionalFilesPage] UI_CREATOR=AddAdditionalFilesPage UI_SOURCE=Setup\DeployUi.dll UI_CONDITION=ADSK_LAUNCH_MODE="DEPLOYMENT" OR ADSK_LAUNCH_MODE="MINIMAL_DEPLOYMENT" [WorkstationSettingPage] UI_CREATOR=WorkstationSettingPage UI_SOURCE=Setup\DeployUi.dll UI_CONDITION=ADSK_LAUNCH_MODE="DEPLOYMENT" OR ADSK_LAUNCH_MODE="MINIMAL_DEPLOYMENT" [StartTabSettingsPage] UI_CREATOR=StartTabSettingsPage UI_SOURCE=Setup\AcDeployUi.dll UI_CONDITION=ADSK_LAUNCH_MODE="DEPLOYMENT" OR ADSK_LAUNCH_MODE="MINIMAL_DEPLOYMENT" [ServicePackPageForDeploy] UI_CREATOR=ServicePackPage UI_SOURCE=Setup\SetupAcadUi.dll UI_CONDITION=ADSK_LAUNCH_MODE="DEPLOYMENT" OR ADSK_LAUNCH_MODE="MINIMAL_DEPLOYMENT" [ServicePackPageForInstall] UI_CREATOR=ServicePackPage UI_SOURCE=Setup\SetupAcadUi.dll UI_CONDITION=ADSK_RUNNING_FROM_ADMIN="FALSE" AND NOT ADSK_LAUNCH_MODE="DEPLOYMENT" AND NOT ADSK_LAUNCH_MODE="MINIMAL_DEPLOYMENT" [InfoCenterCommCenterPage] UI_CREATOR=InfoCenterCommCenterPage UI_SOURCE=Setup\DeployUi.dll UI_CONDITION=ADSK_LAUNCH_MODE="DEPLOYMENT" OR ADSK_LAUNCH_MODE="MINIMAL_DEPLOYMENT" [OnlineResourcesPage] UI_CREATOR=OnlineResourcesPage UI_SOURCE=Setup\DeployUi.dll UI_CONDITION=ADSK_LAUNCH_MODE="DEPLOYMENT" OR ADSK_LAUNCH_MODE="MINIMAL_DEPLOYMENT" [AdAppManPage] UI_CREATOR=AdAppManPage UI_SOURCE=Setup\DeployUi.dll UI_CONDITION=ADSK_LAUNCH_MODE="DEPLOYMENT" OR ADSK_LAUNCH_MODE="MINIMAL_DEPLOYMENT" [A360CustomConfigPage] UI_CREATOR=CustomConfigPage UI_SOURCE=Setup\A360SetupUi.dll #============================= Common Main Pages: Maintenance Mode ============================= [OemPreinstallLicenseDlg] UI_CREATOR=LicenseDialog UI_SOURCE=Setup\SetupAcadUi.dll UI_CONDITION=ADSK_OEMPREINSTALL="1" [OemPreinstallProductInfoDlg] UI_CREATOR=ProductInfoDialog UI_SOURCE=Setup\SetupAcadUi.dll UI_CONDITION=ADSK_OEMPREINSTALL="1" [MaintenanceDlg] UI_CREATOR=MaintenanceDialog UI_SOURCE=Setup\SetupAcadUi.dll UI_CONDITION=NOT ADSK_OEMPREINSTALL BACKGROUND_IMAGE=SetupRes\AutoCAD.png [AddRemoveFeaturesDlg] UI_CREATOR=AddRemoveFeaturesDialog UI_SOURCE=Setup\SetupAcadUi.dll UI_CONDITION=NOT ADSK_OEMPREINSTALL AND NOT REINSTALL="ALL" AND NOT REMOVE="ALL" [RepairDlg] UI_CREATOR=RepairDialog UI_SOURCE=Setup\SetupAcadUi.dll UI_CONDITION=NOT ADSK_OEMPREINSTALL AND REINSTALL="ALL" [MaintVerifyReadyDlg] UI_CREATOR=MaintVerifyReadyDialog UI_SOURCE=Setup\SetupAcadUi.dll UI_CONDITION=NOT ADSK_OEMPREINSTALL [MaintCompleteDlg] UI_CREATOR=MaintCompleteDialog UI_SOURCE=Setup\SetupAcadUi.dll UI_CONDITION=NOT ADSK_OEMPREINSTALL AND ADSK_SETUP_SUCCEEDED BACKGROUND_IMAGE=SetupRes\AutoCAD.png [MaintFailedDlg] UI_CREATOR=MaintFailedDialog UI_SOURCE=Setup\SetupAcadUi.dll UI_CONDITION=NOT ADSK_OEMPREINSTALL AND NOT ADSK_SETUP_SUCCEEDED BACKGROUND_IMAGE=SetupRes\AutoCAD.png [ACAD_LP_en-US] UPI2_x64={51D275DF-61DB-4007-BE0F-13250138C05E} DISK_LABEL=acad2016 DISK_PROMPT=AcSetupRes.dll;11 [ACAD_MAIN_en-US] UPI2_x64={143669D1-05D9-46B3-94D0-4A63B66A9799} DISK_LABEL=acad2016 DISK_PROMPT=AcSetupRes.dll;11
Cordialement,
Restant a votre disposition,
Cordialement,
Merci pour vos informations.
Je vous prie de remplacer votre fichier setup.ini par celui intégré dans cet email (à renommer avec l'extension .ini). Vider votre répertoire %tmp% et tentez une nouvelle installation.
Rencontrez-vous toujours un problème ?
Si oui, je vous prie de répondre au courriel se référant au cas 12650420 pour une assistance individualisée.
Pour toute autre information, je reste à votre disposition.
Vous n'avez pas trouvé ce que vous recherchiez ? Posez une question à la communauté ou partagez vos connaissances.
