Show only
Search instead for
Please allow 3D Perspective camera views to be supported for analysis. This is helpful for presenting the results in a spatially understandable way. Better yet, simply provide a toggle for a default 3D perspective view!
Are you referring to using 3D perspective views for lighting analysis? If so, you can do lighting illuminance renderings for 3D perspective views by using the Render in Cloud workflow.
Revit 2020 supports generating Analysis Results (like Lighting and Solar) in a 3d perspective view. The display results also not support transparency colors.
Check this out with the new release of Insight with significant Lighting updates:
