Addding more options for HVAC systems
I would like to be able to get a bit more specific on my HVAC systems, such as a ground source heat pump or chilled beam system. At least the ability to add one and edit specific parameters.
2 Comments
AaronK_EXT-2145
It'd be great to select which HVAC system is being used for the ASHRAE baseline energy model (using the 90.1 appendix G).
Recently, found a discrepancy between Insight and Train Trace 700... both got the same "As-Designed" EUI of 41.4 and 41.5, but their ASHRAE baseline models were 79.2 EUI and 58.2 EUI respectively.  Found out that Insight is using a VAV system for the baseline model instead of the Roof-top Heat Pump system that 90.1 G requires, just because the building type is Office.  It'd be great to adjust which system the ASHRAE model uses.
(Also YES to the being able to set a custom HVAC system in Revit's energy settings... or even just being able to select a Ground source heat pump)
sdcartmell
