Your Analysis failed.
sandramVA6Z5
Observer Observer
sandramVA6Z5
Observer
Observer
Hello I keep receiving the same error message but have no idea what this means?
Please advise.
Hi @sandramVA6Z5
What you are running into is a limitation of the DOE-2 analysis engine used by Insight. There is a problem with some of the construction elements in your model. The error message indicates that one of the layers (constructions) is too thick/or too thin, or has a very high, or very low thermal mass. Unfortunately this is a limitation of the energy analysis engine used by Insight (DOE-2). Some combinations of thermal properties lead to numerical instability in DOE2; however there are no definitive guidelines since the limitations are combinatorial relationships between thickness and material density. You may or may not have added these constructions intentionally, as they are tied to Revit construction elements and materials in some cases. Go to Energy Settings >Advanced >Material Thermal Properties and Disable ‘Detailed Elements’ and Generate Insight again. This will use only the Insight default constructions (refer to View and Modify Conceptual Types, and Material Thermal Properties – Conceptual Typesfor more information on the Insight constructions). If you wish to use the custom constructions in your model, review all of your construction elements and look for any with very high or low thermal mass (an example could be very thick layers of steel or concrete or multiple layers of thick insulation; or a single think layer of steel or single layer of gypsum board). Go to this Revit help topic for additional information: Use Detailed Elements for Material Thermal Properties.
Please click the "Accept as Solution" button if this solves your issue or answers your question so that others may also benefit from the information.
