GBS Access for Student user: "you do not currently have access to this service"
I have signed into Green Building Studio and to the Autodesk Student Community.
When I run Revit, I am logged into the Autodesk 360 service.
I can run a render in the cloud.
I am trying to complete the online tutorial "Whole Building Energy Analysis with Revit Course" at http://academy.autodesk.com/courses/www/student.php?view_unit=2114
When I run Energy Analysis: I obtain the message that others have been getting: "you do not currently have access to this service. Your license period for the sharing service has ended"...
No further ideas come to mind at present, and I am supposed to be reporting to my colleagues tomorrow what they need to include in our collective BIM model that will enable this energy analysis to occur.
NOTE: the GBS subscription when I log into gbs.autodesk.com seems to be a trial for two runs only. Is this correct?
Kathlen
Replies (7)
even i am having the same problem
my id is kevalpathaksmailbox@gmail.com
Mohammad_Asl
Can you try to run a simulation again. We addressed the issue on the background. Otherwise please email mohammad.asl@autodesk.com your user account and  will track the issue.
Mohammad Asl
High Performance Building Design Researcher
Autodesk, Inc.
Insight360.support@autodesk.com
hi thanks so much its working now,
but i want to ask why does it takes time after creating the  student id ,and installing student version ,,after 2 days i was able to run energy simulation
previously it showed be u dodnt have currently access to thius service ,you licenc
e persion for sharing service has ended ,,,,
and also wanted to ask how long this student subscription is valid for ?
AUTODESK:
I have the same "you do not currently have access to this" message render when I attempt to run an energy analysis. I am tasked with the BPAC from my instructor at my university.
I know that I have accidentally created two profiles in A360. That may be the problem.
TJ
email: tjleonard@gus.pittstate.edu
mstein7484
Hi Everyone,
Our apologies for all of the problems you have been encountering.
  1. The service is limited for trial accounts. You should delete your existing trial account and start fresh, following these steps. You need to make sure you activate your Green Building License in addition to your Revit license. From the Education Community; Download & register Revit, then activate GBS. This page explains the process in more depth."
  1. If you have two education accounts log into Green Building Studio (the simulation engine used by Revit and Insight 360), for each one and look at the “My Account” tab to make sure they are not a trial account, or expired. You can have only one account associated with an email address. Only use the active, full subscription account. Otherwise follow the same process outlined above.
Marjorie Stein
QA Analyst
Generative Design Group
Autodesk, Inc.
insight.support@autodesk.com
I'm having that same problem, how can i fix it?
it was working fine yesterday, I still have the files i created in Insight360.
As for my Account on Green Buildin Studio it is Active and not a trial or expired,
my id is aefuentespadilla1@sheffield.ac.uk
Please help me
thanks in advance
mstein7484
We have a temporary user account for students to use for generating Insight 360 while we work on restoring your account access.
Please delete your projects when you are finished with them.
autodesk.insight360@gmail.com
password: Student01
Thanks for your patience while we work work on your account access.
Marjorie Stein
QA Analyst
Autodesk, Inc.
