Error: Issue: An error has occurred related to the DOE-2 simulation
sbaghaii
sbaghaii
I can't figure out what is generating the error below. I thought maybe there was an issue with how things are modeled since the project is in the early schematic phase so I switched to conceptual mass but got the same error. It is not one of the standard errors that are listed on the Autodesk help forum. The energy model is generated without any errors, but when I send it to the cloud to be analyzed I get the error below.
Error: Issue: An error has occurred related to the DOE-2 simulation. It is below and may be of assistance in determining the issue with your building model. <br/> *4462 * V1 = ( 571944.32957500, 720342.871066001 )<br/>*ERROR**************** =============== *******************************************************<br/>*ERROR*****VALUE NOT BETWEEN -52800.0000 AND 52800.0000<br/>*ERROR*****VALUE NOT BETWEEN -52800.0000 AND 52800.0000<br/>*ERROR********************************* ================ *************************************<br/>*ERROR*****VALUE NOT BETWEEN -52800.0000 AND 52800.0000<br/> *4464 * V2 = ( 572017.523397001, 720342.871066001 )<br/>*ERROR**************** ================ ******************************************************<br/>*ERROR*****VALUE NOT BETWEEN -52800.0000 AND 52800.0000<br/>*ERROR*****VALUE NOT BETWEEN -52800.0000 AND 52800.0000<
I am not clear what value is not between -52800.0000 and 52800.0000. If I knew that I could hopefully fix this issue.
melizardo
You're going to have to reset your shared coordinates. I would detach the model before you do this to your central model. I would never recommend you do this to your main model. Your project base point could be way outside. In revit 2021 and up you can reset the shared coordinates easily.
sbaghaii
Thanks! I ended up doing something like this because the development site of the project is so large so the project base point in the main model is too far from the buildings.
