Can I define electricity but also gas consumption for the same space?
a88129
a88129
In my kitchen, there is several electrical equipment but also gas equipment. However, in REVIT I can only define the power density of the equipment, and then in Insight it will assign everything as if it were electrical energy.
What should I do to obtain the gas result?
giuseppe_ardito
Hi @a88129
Thank you for reaching out!
To incorporate gas equipment into space systems and understand their impact on energy consumption based on current Revit and Insight capabilities, I suggest the following approach:
Define the gas equipment in Revit as part of the Power Loads, using a conversion factor to translate fossil fuel consumption into electricity usage. A common rule of thumb is that 1 kBtu of fossil fuel consumption typically equals 3 to 5 kBtu of electricity. You can apply this ratio to include gas consumption in the Power Loads in Revit and run a simulation.
However, the gas consumption will still appear under electricity usage in the EUI breakdown, as Revit currently does not support the inclusion of gas equipment per-space .
