analysis failed
analysis failed
maha_ghali
Observer Observer
analysis failed
maha_ghali
Observer
Observer
Your analysis failed.
Detailed status:
Model: MG_RG
Error: Issue: An unrecoverable internal error has occurred.
giuseppe_ardito
Hi @maha_ghali
thank you so much for posting your issue on the forum.
Which Revit version are you using? Is there a chance you can share your model?
Can you try to run your model in Insight Carbon Analysis and not Insight/GBS? You should launch the analysis from the button I highlighted in the screenshot.
I look forward to hearing from you.
Best,
maha_ghali
Observer
Observer
Thank you for your help. Actually, I think it’s a modeling issue, and all of this could have been resolved by making a few adjustments directly to the model.
frida_pedrazadlg
Observer
Observer
Hi @maha_ghali  !! I had the same problem. I received that notification in my email stating that the model couldn't be processed. Were you able to solve it? Or what was the error in the model that you mentioned? I want to check if it's the same issue with my model.
giuseppe_ardito
Hi @frida_pedrazadlg ,
did you try to run your model with the Next Generation of Insight?
Best,
Giuseppe
