Analysis Failed
dhergar2
Observer
Analysis Failed
dhergar2
Observer
Observer
Trying to make the Energy Analytical model on Insight, keep failing and I receive the following message, How can I fix it?
Your analysis failed.
Detailed status:
Model: Hernández_Daniel_Entrega02
Location: Calle La Rodana, 186, Sagunto, Valencian Community
Error: Issue: An error has occurred related to the DOE-2 simulation. It is below and may be of assistance in determining the issue with your building model. <br/> * 247 * ..<br/>*ERROR****************************************************************************************<br/>*ERROR*****Cannot simulate LAYERS aim2492 as given. The wall is too thin or<br/> U-VALUE CONSTRUCTION.<br/>*ERROR****************************************************************************************<br/>*ERROR*****Cannot simulate LAYERS aim2492 as given. The wall is too thin or<br/> * 316 * ..<br/>*ERROR********* == ***************************************************************************<br/>*ERROR*****aim2492 has no data due to previous error<br/>
giuseppe_ardito
Hi @dhergar2 ,
thank you for reaching out the community forum.
Is there a chance you can try to run your model on the next generation of Insight?
You can trigger the embodied, operation carbon and energy analysis directly from Revit.
I am attaching here a screenshot.
I look forward to hearing from you.
Best,
