Good afternoon,
I am trying to use Revit transfer to Green Building Studio and Insight 360 for analysis. I have to main questions.
1/ With the same file sent to GBS and Insight 360, the 'BIM' baseline presented via Insight 360 is supposed to be the same as the data I can check under in GBS under "Building details and assumptions" (eg. for thermal properties of the walls) right? The reason I am asking this is that under Insight 360, wall construction R value can't be checked, it just says 'as modeled' value, and as savings are shown when changing for 'R2 cMU' it would mean that Insight 360 considers a R value from the baseline as being below R2 CMU which is not the case as you can see on the screenshot form GBS below.
2/ A file is indeed sent to GBS and Insight 360 and I'd like to make sure that areas are properly transferred and understood. Attached is the gbxml file transferred and saved from GBS. I am confused by the huge amount of 'air openings' I can read in GBS under "Building details and assumptions" as when I check the file via Revit/3d view energy model/ analytical surfaces/ air openings, I don't see this amount at all...
thanks a lot in advance for your help,
Regards
Aurelie
Solved by mstein7484. Go to Solution.
Hi Aurelie,
You are correct that you can check the BIM settings used in Insight in the Base Run in GBS.
There are many thermal properties that factor into the energy efficiency of a building material. The description of the wall construction "R2 CMU" refers to the r-value of the insulation (R-2) only and not the total u-factor of the entire wall assembly.
Good morning,
thanks for your answers,, below are my answers and questions
Aurelie
please send the .rvt file & let us know what version of Revit was used to create it.
I am trying to send those but they are 43MB so not sure if you received a link to download those?
a.
I will invite you to our Autodesk Box account. What is your email address? You can send it to me via pm if you want.
you should be able to upload your model here:
https://autodesk.app.box.com/files/0/f/xxx-xxxxxxxx/Aurelie
Hi Aurelie,
One of the people on our team took a look at your model and has some tips for you.
First of all, in order to create an energy model from a detailed architectural read and apply this section of the Revit help.
http://help.autodesk.com/view/RVT/2017/ENU/?guid=GUID-32BD5A12-DF5B-4B51-B51A-D799C729A78A
You can also create massing or ‘mixed’ models quickly specially for energy analysis which is often easier and more informative, see:
http://help.autodesk.com/view/RVT/2017/ENU/?guid=GUID-A77EF18D-0EB8-47D3-A653-6370D9F1374A
Beyond that some other tips:
o Create a new project using the Architecture template
o Open the model architecture 2017
o On the Manage tab click the tool Transfer Project Standards
o Click “Check None”, then check “Object styles” > OK > click “Overwrite”
o >> Colors should update.
He also found an 8”/4” resolution and found a small gaps in the basement. See the attached screenshot.
Let us know if you have more questions on this topic, otherwise please accept as a solution so that others can benefit from this information.
