We are looking to find a way to export a PDF report that documents each widget setting and the resulting EUI.
Does this functionality exist? If not, can it be added?
Solved by mstein7484. Go to Solution.
In our upcoming release (next month) Insight will now have the capability to export .png files of all the widget settings, the Benchmark Comparison widget, and the Energy Cost Range dial. In addition to the ability to export the energy files for DOE2, EnergyPlus, and gbXML files.
Let us know if you have more questions on this topic, otherwise please accept as a solution so that others can benefit from this information.
Hi @yledemarco
Yes, you can now export the following by expanding the options menu on you model in Insight:
See the screenshots.
Please click the "Accept as Solution" button if this solves your issue or answers your question so that others may also benefit from the information
