Add a transparent background to a feature tooltip
- Mute
- Permalink
- Report
The trick is to declare the background color and opacity attributes within the initial tooltip opening tag.
1) Exit Edit Mode if you are in edit mode.
2) Select the desired feature.
3) Right-click and choose Edit Tooltip
4) Select the HTML tab
For example:
<tooltip background-color=”#fff” opacity=”.5”>
<style>
</style>
</tooltip>
Will provide you with a white background that has 50% opacity. Set opacity to a lower value (minimum=0, maximum=1) to increase transparency.
From there, you can add any number of items to your tooltip, such as embedding a YouTube video or Screencast, adding a hyperlink or iframe, or even a "Show in Google Maps" link.
Check out these additional help resources to extend your tooltip capabilties:
- http://autodesk.typepad.com/bimagination/2015/09/infraworks-360-web-viewing-adds-points-of-interest-...
- http://autodesk.typepad.com/bimagination/2015/04/infraworks-360-adding-a-google-maps-link-to-a-toolt...
- https://forums.autodesk.com/t5/infraworks-360-infratips/add-an-lt-iframe-gt-to-an-infraworks-360-fea...
Principal Specialist, Infrastructure
