Rename Proposals
Rename Proposals
Maybe I missed it, but, if the only way to rename a proposal is to duplicate and give it a new name, then delete the old, could we get the ability to rename the proposals?
Ideally, this will flow through and rename the shared web versions too. I assume this is why it doesn't already do this.
10 Comments
Steve_Th
To Add:
Could it also order the proposals by name alphabetically?
Hi @Steve_Th,
We put together this script for you, I think this will accomplish the renaming portion of what you are looking for. Here's some information on how to use the scripting console: http://help.autodesk.com/view/INFMDR/ENU/?guid=GUID-6CCCDB7F-E136-42A1-ACE2-F119EAF75B6B
var doc=app.ActiveDocument();
doc.ChangeProposal("oldname");
doc.AddProposal("NewName");
doc.RemoveProposal("oldName")
I'll see if I can create a Print function to help with the request to order alphabetically.
Elliott
Steve_Th
Hi Elliot,
Thanks for this.
Works Great!
This is kind of dangerous....I accidentally put a space in the "NewName", and running it just removed the old proposal. However it still was in the cloud. There really should be a better way. Renaming things is fairly common.
Jennifer.Miedema
@elliott.rosenfeld
Thanks for the script! Definitely tucking this one away into my toolbox 🙂
Cheers!
ThomasBHansen_
Agreed! This should be an included feature, not a script.
ramesh_sridharan
I agree this is nice to have but since there is a copy/delete workaround this keeps getting pushed down.
pieter_haeck
@ramesh_sridharan With all due respect, where is the logic of this? So, basicly, for every missing feature (that could save time/money) for which there is a workaround, there are very little intentions to improve the software?? This little 'request' lies in man's logical thinking and thus action. Why make it unnecessarily cumbersome? #justathought
ramesh_sridharan
@pieter_haeck It is just that other items that got more value to the users that can save time/money take precedence over this. Let me bring this with the team to see if we can prioritize this. Thanks and sorry for the inconvenience.
bradley.cooley
This is an odd limitation for Proposals.... running the renaming script is a helpful workaround.
Adding the Edit Feature to Proposal like we have with Bookmark would be much better.
