Profiles for Double Decker Bridge Component
Hi, In Infraworks model preparation of Double Decker Road Bridge. I made a custom bridge component by using Inventor and Revit. Now, How can i assign two profiles (viz. Bridge tier 1 and tier 2) for this bridge component in Infraworks?
1 Comment
ara.ashikian
Status changed to: Gathering Support
In InfraWorks, when you have double decker road bridges, you need to model 2 separate bridges.  One for each road.  This will allow the superstructure (deck and girders) to properly follow each road.  The piers of the lower bridge would need to be positioned to be aligned with the corresponding pier of the upper bridge.  The lower bridge's pier at such locations would be custom piers that could consist of only the piercap.  This will let the user control the slopes or steps etc.  This custom pier would need to have geometry compatible with the columns of the upper pier so that visually, it fits well.  Both bridges can then be published together into a Revit model for drawing production etc.
