Pedestrian Bridge Tools
I have had some success using the bridge tools to create pedestrian bridges, however, we could use more tools, or even presets to address the needs associate with this type of bridge. For instance, ped bridges will often use ramps with switch-backs or spirals, or elevator and stair systems. The bridge tools are ideal for bridge functions, but the adjoining elements (design and component roads) don't always work so well.
This tool would be particularly useful when conceptually designing a ped bridge to fit within a VERY tight tolerance. Where does the bridge land, will it impinge on right of way, will it have enough clearance, will the height of the bridge allow enough ramp at the appropriate grade to fit within the project footprint, how much material would be required to build, etc.
1 Comment
ara.ashikian
Using custom parametric Inventor based components to add these pedestrian bridge details might provide the level of flexibility and functionality that you are looking for.  Btw, in the upcoming release of InfraWorks, we have made big improvements in the workflow to add and manage custom Inventor based parametric bridge content.  Project Kameleon from labs will no longer required for custom bridge content.  We have posted a video on the Rolling Sandbox forum.
Can you provide a few examples of the type of pedestrian bridge layouts that you are using?  We could then provide more specific guidance.
Regards
-Ara
PM InfraWorks Bridges
