Include in the AEC collection Inventor
I think this is not exactly the right address. But I do not know where to write. Infrastructure Parts Editor requires an Inventor. But it is not in the collection. To be able to create a component, you need to buy Inventor. This increases the cost of the workplace by almost 2 times. Perhaps the developers can influence the composition of the collection.
2 Comments
ChrisRS
This is new and confusing.
I believe that this new parts creation engine is in two parts.
Part 1 is the "Infrastructure Modeler"(IM)  add-in for Inventor or Inventor LT.
Part 2 is the "Infrastructure Parts Editor" (IPF)that launches from inside of InfraWorks or Civil 3D.
@alexey.kurenkov, my understanding is that "Inventor LT" is adequate to run the "IM."
I would be satisfied if "Inventor LT" was added to the AEC Collection.
Inventor is $50/mo or $380/year so it is more affordable than Inventor at $235/mo or $1,890/year. I still think it should be included in the AEC Collection.
Autodesk will suggest that you might want to do a one month rental of LT, create your content and be done with rental. I generally do not agree, but there may be some merit to this suggestion:
As I understand it,
  • You only need to create one prototype (parametric) model in Inventor/IM.
  • Using IPE, you convert that model to a part that you can copy and modify to crate a part family. That is you use IM to create a 8-inch "Widget" model, then use ICE to make 8-inch, 10-inch and 12-inch Widget parts.
  • Then use IPM to add these parts to a catalog to use with IW or C3d.
Months later you have a need for a 6-inch and 18-inch widget. Using IPE create 6-inch and 18-inch Widgets, based on the model you created in step 1. You do not need Inventor/IM again.
If the base catalog has a part that is close to what you need, you may be able to use IPE to copy and modify the existing part with out using Inventor/IM.
Like I said, this is confusing.
The IM/IPE combination does not add great functionality to IW and C3D; it helps users fill gaps in the content provided by Autodesk. I do not want to learn Inventor, but I will, if I need it to patch IW and C3D. I resent having to rent Inventor LT to do so. The optics suck.
alexey.kurenkov
Infrastructure Parts The editor does not contain suitable elements for us. You need to create many elements. If the LT Inventor is enough for this, it's good. I just started to study this opportunity. And the first thing it took was an inventor.
