Export of selected objects
Currently there is the option to either define a bbox or polygon for export, it would be good to have another option to select single objects for export, for example two buildings.
3 Comments
Are you exporting to another Infraworks model or to .IMX?
The right-click --> Copy and Paste In Place options work from one model to another and help with correct placement of the copied components.
You can also use this as a workaround for .IMX export by copying and pasting select objects from your primary model into a new file and exporting the new file instead.
It's a multi-step process, but does allow for exporting of selected objects.
u610064
@Anonymous Thanks for your helpful answer. I need this function to export * .fbx files into 3ds Max.
SteveDFThorne
Pretty sure there is no copy / paste for design roads or component roads
