Coordinate System Support for China (CGCS 2000)
Since 2008, China has fully adopted CGCS 2000 as its unified coordinate system. CGCS 2000 (China Geodetic Coordinate System 2000) is similar to LL84 but has a slight deviation. At present, all Chinese users must use coordinate offset to realize each data interaction. China is one of the countries with the most InfraWorks users. Please provide the CGCS 2000 coordinate system and relevant projected coordinate systems to help users directly use the accurate coordinate position in InfraWorks. Thanks!
5 Comments
I hope it can be realized as soon as possible!
thanks!
honglei.chen
This will be very helpful for Chinese users, and I hope it can be implemented soon.
Nora.Li
We are looking into this issue together with Map 3D team as it actually affect not only InfraWorks, but also Civil 3D, ReCap and Map 3D who are using the spatial libarary. In short term, we may try to define the custom CS and share with others, hope this will be helpful.
https://knowledge.autodesk.com/support/autocad-map-3d/getting-started/caas/simplecontent/content/cre...
https://knowledge.autodesk.com/support/autocad-map-3d/learn-explore/caas/sfdcarticles/sfdcarticles/S...
