InfraWorks Forum
Welcome to Autodesk’s InfraWorks Forums. Share your knowledge, ask questions, and explore popular InfraWorks topics.
what are levels in acc infraworks models?
3 REPLIES 3
itzhakLFGFA
231 Views, 3 Replies
Hello.
What are the levels in acc infraworks models?
What kind of information should be included in this section?
Thanks....
3 REPLIES 3
Matheus-Lima
in reply to: itzhakLFGFA
Hi, @itzhakLFGFA!
I believe this is more applicable to Revit Files. These levels are basically what guide 3D modelling like a limit to extrude objects: https://help.autodesk.com/view/RVT/2024/ENU/?guid=GUID-54EDD889-9AEA-40B5-BD60-FC2F860DF95D.
Quick video below navigating though levels in a Revit model:
[PT-BR] Se essa postagem foi útil para você, clique em Curtir! Se a resposta resolveu o seu problema, clique em Aceitar Solução.
[EN-US] If it was helpful to you, click on Like! If the answer solved your problem, click on Accept Solution.
Matheus Lima
Civil Engineer | BIM for Infrastructure Enthusiast | BIM Manager | Instagram @bim_infra | LinkedIn
itzhakLFGFA
in reply to: Matheus-Lima
Thank you.
itzhakLFGFA
Rail Community
