HI,
I have a problem with 2 proposal.
I created a model choosing an area for master proposal., then i created another proposal.
On the attached file you can see two image. On the right is MASTER Proposal, on the left is another proposal.
On the master i can see the correct texture of the map, on the other proposal I can't see the correct texture.
There is an option to set?
thanks
Stefano
I have found the problem.
On all other proposal I have configure the data source of terrain image and update it.
Why when i create a new proposal i have to do this?
