Utilizing Shapefile Attributes under style Rules
L3GO-Ed
L3GO-Ed
I was wondering if it is possible to use gis-shapefile attributes when creating styles rules. I am working on a road project and would like to create a style rule that picks up the Traffic sign name/code to apply a particular style. I have a shapefile with an attribute of the name of each signage position and I was hoping I could take advantage of this attribute information.
This would save me a great deal of time if it is possible.
andrewofabley
@L3GO-Ed
Yes, this can be done by rule style.
Map the attribute first in the data config, then write an expression to assign a model to it in the style rule.
You can select the rotation, scale, and offset, all by mapping the attributes from the shape file.
AEC Collection / Safe FME / ESRI ArcGIS / Unreal Engine
Digital Engineering Lead, Compulsive Problem Solver.
L3GO-Ed
Thanks Andrew.
