Use "Paste In Place" when copying objects between Proposals
Select the object[s] you want to copy between Proposals and Right-Click Copy. Note: you will need to exit Edit mode if active.
Switch to the Proposal you want to add the Copied object[s], and Right-Click Paste In Place. Note using Paste In Place copies the objects to the exact point they were copied from. Using Paste... forces you to manually locate the location of your Pasted object.
Repeat as necessary for additional Proposals.
Willy Campbell
